Thanks, Ralph
But where I can get the module CA Put Logging
itself? In CA Put Logging doc page (link from Epics Extensions web page) is
written that for epics 3.13.4 and higher : "All the necessary routines and
libraries to provide Trap Write Hook are placed into base. Modules dealing with
CA Put Logging are placed in the directory EpicsBase/src/caPutLog"
... Trap Write Hook is there, in base release. Where to find
caPutLog? I tried to access DESY ftp server (link from CA Put Logging
doc page) with hope that I could find it there but link failed.
Can you help please?
Vladimir
----- Original Message -----
Sent: Friday, September 16, 2005 12:40
PM
Subject: Re: TRAPWRITE and logging CA_PUT
activity
Hi Vladimir,
It's exactly as you were citing from the
Release Notes:
EPICS Base itself does not provide this ability, but
only the hook needed by such a facility. This new hook facility is
described in more detail in the 3.14 Application Developer's Guide, in chapter
8.8 ("Trapping Channel Access Writes").
Documentation on the DESY "CA
Put Logging" module, which can be hooked into this facility, can be found on
the DESY page that can be reached from the "Extensions" page of the EPICS Web
(section "Other Tools or Libraries").
There are no plans to include
such plug-in modules into EPICS Base.
Hope this
helps, Ralph
Vladimir Sirotenko wrote:
Can anyone answer the following question: is
mechanism to log ca write activity implemented in 3.14 base epics release?
According to documentation, it is supposed to
( http://www.aps.anl.gov/asd/controls/epics/EpicsDocumentation/ReleaseNotes/ReleaseNotes3.13.4.html :
"The purpose of this new
facility is to allow things like logging Channel Access writes. Epics base
itself does not provide this ability but only the hook needed by such a
facility. DESY has developed a facility that logs CA puts. The trap writes
feacure allows the DESY facility to be implemented without any changes to
epics base. In addition it allows the user to decide what should be logged.
This new facility will be described in more detail in the 3.14 version of
the Application Developer's Guide."
but if I just look for the presence of
environmental name EPICS_IOC_CA_PUT_LOG_INET or as was suggested by
V.Korobov name which is supposed to be used in later CA_PUT release:
EPICS_IOC_LOG_CONFIG_FILE_NAME, then both are missing in src directory of
the epics base 3.14.6
Does anyone use such tools? And
how?
Vladimir
- Re: TRAPWRITE and logging CA_PUT activity Ralph Lange
- TRAPWRITE and logging CA_PUT activity Vladimir Sirotenko
<2005>
<2005>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
