1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: archive viewer installation problem
To: "Chevtsov, Sergei" <[email protected]>
Cc: Claude Saunders <[email protected]>, Christophe Moins <[email protected]>, [email protected]
Date: Wed, 07 Sep 2005 14:44:55 -0700
Hi, everyone!
I rebuilt AV with Java 1.4, so all problems should be gone now.
Sorry for inconvenience.
Sergei
Chevtsov, Sergei wrote:
Hi, Christophe!
Claude is correct, and I apologize for not testing the new build under 1.4 :-(
Unfortunately, I have no access to SNS CVS right now, so I will be able to fix it only when I am back from my vacation next Wednesday.
To all:
Btw, how many people still use Java 1.4?
Sergei
-----Original Message-----
Sent: Fri 9/2/2005 9:08 AM
To: Christophe Moins
Cc: [email protected]
This looks very much like the xal.jar (and hence MessageCenter.class) was built with JDK1.5, whereas you are compiling and building with JDK1.4. I've used classes across the transition from JDK1.3 to JDK1.4 before without a problem, but it looks like there are more incompatibilities between 1.4 and 1.5. It's nice that the compiler flags it, but the error message is a bit obtuse.
SNS builds XAL with JDK1.5 now, so you either have to move up to 1.5, or request a jar file built under 1.4. I'm not sure if they have coded in 1.5 specific features, so that may or may not be possible.
- Claude
Christophe Moins wrote:
Hello,
I am trying to install archive viewer but I have the following message when I launch the ant command in Archiveviewer's top directory :
Buildfile: build.xml
-create_build_dir:
build_all:
[javac] Compiling 842 source files to /root/archiveviewer/build
[javac] /root/archiveviewer/src/epics/archiveviewer/base/AVBase.java:25: cannot access gov.sns.tools.messaging.MessageCenter
[javac] bad class file: /root/archiveviewer/ext_jars/xal.jar(gov/sns/tools/messaging/MessageCenter.class)
[javac] class file has wrong version 49.0, should be 48.0
[javac] Please remove or make sure it appears in the correct subdirectory of the classpath.
[javac] import gov.sns.tools.messaging.MessageCenter;
[javac] ^
[javac] 1 error
BUILD FAILED
/root/archiveviewer/build.xml:21: Compile failed; see the compiler error output for details.
Total time: 18 seconds
Does anybody what's going on ?
Thanks
Christophe
RE: archive viewer installation problem Chevtsov, Sergei
Prev: Controls Group positions at SNS Gurd, David P.
Next: animation and 3-d Bob Dalesio
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: archive viewer installation problem Chevtsov, Sergei
Next: Keithley 237 Luchini, Kristi
