1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: SNCSEQ...
To: "Laznovsky, Michael" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 02 Sep 2005 09:45:13 -0500
Laznovsky, Michael wrote:
	gmake[1]: Entering directory `/u/cd/xyz/tmp-xyz/ioc/configure'
	perl <SLACstuff>/epics/R3.14.6/base/configure/tools/convertRelease.pl -h solaris-sparc checkRelease
	Definition of SNCSEQ conflicts with SNCSEQ support.
	In this application configure/RELEASE defines
	        SNCSEQ = /u/cd/xyz/work/seq-2.0.10
	but SNCSEQ at  has
	        SNCSEQ = <SLACstuff>/epics/R3.14.6/site
gmake[1]: *** [checkRelease] Error 1
I don't see where the second definition in the error comes from. It's not anywhere in the installed EPICS area that I can find.
Is the text above *exactly* as reported by the tool, or did you edit the two "<SLACstuff>" parts? I note that the second line above has <SLACstuff> in the path to the convertRelease.pl script, and that looks to be part of the problem. Check whether SNCSEQ (or SLACstuff even) is found anywhere in your <base>/configure directory. Do you use an automounter that uses soft links and gives different paths to mounted file systems?
There should be a path printed in between the words "but SNCSEQ at" and "has"; if that path really is empty it could be reading a file from the root path /configure/RELEASE so have a look there too. Finally, I'm not sure what will happen if the SNCSEQ installation itself has a definition for SNCSEQ in its own configure/RELEASE file, so make sure there isn't one set there.
Let us know what you find...
- Andrew
English arose from Normans trying to pick up Saxon girls.
SNCSEQ... Laznovsky, Michael
Prev: archive viewer installation problem Christophe Moins
Next: Re: archive viewer installation problem Claude Saunders
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: SNCSEQ... Ernest L. Williams Jr.
Next: Re: SNCSEQ... Emmanuel Mayssat
