1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: archive viewer installation problem
To: [email protected]
Date: Fri, 02 Sep 2005 14:53:22 +0200
Hello,
I am trying to install archive viewer but I have the following message when I launch the ant command in Archiveviewer's top directory :
Buildfile: build.xml
-create_build_dir:
build_all:
[javac] Compiling 842 source files to /root/archiveviewer/build
[javac] /root/archiveviewer/src/epics/archiveviewer/base/AVBase.java:25: cannot access gov.sns.tools.messaging.MessageCenter
[javac] bad class file: /root/archiveviewer/ext_jars/xal.jar(gov/sns/tools/messaging/MessageCenter.class)
[javac] class file has wrong version 49.0, should be 48.0
[javac] Please remove or make sure it appears in the correct subdirectory of the classpath.
[javac] import gov.sns.tools.messaging.MessageCenter;
[javac] ^
[javac] 1 error
BUILD FAILED
/root/archiveviewer/build.xml:21: Compile failed; see the compiler error output for details.
Total time: 18 seconds
Does anybody what's going on ?
Thanks
Christophe
Re: archive viewer installation problem Claude Saunders
Prev: Re: SNCSEQ... Ernest L. Williams Jr.
Next: Re: SNCSEQ... Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: SNCSEQ... Laznovsky, Michael
Next: Re: archive viewer installation problem Claude Saunders
