We use hyphens in our IOC names under EPICS R3.14.7.
I don't remember making any modifications to support this.
For example,
[williams@lion test]$ makeBaseApp.pl -t example example
[williams@lion test]$ makeBaseApp.pl -i -t example my-new-ioc
The following target architectures are available in base:
vxWorks-mv2100_v6
vxWorks-mv5100_v6
vxWorks-ppc603_T2-2
vxWorks-ppc603_long
vxWorks-ppc603
linux-x86
vxWorks-ppc604_T2-2
What architecture do you want to use? vxWorks-ppc603
[williams@lion test]$ ls
configure/ exampleApp/ iocBoot/ Makefile
[williams@lion test]$ ls iocBoot/
iocmy-new-ioc/ Makefile nfsCommands
Works perfect.
On Thu, 2005-09-01 at 13:48 +0100, Denison, PN (Peter) wrote:
> The build system in R3.14 won't cope with IOC names containing hyphens
> (or any other character permitted in filenames, but not permitted in C
> identifiers). This is a problem for us with our current naming
> convention. It occurs because the auto-generated
> <name>_registerRecordDeviceDriver.cpp file uses the app name to
> construct a function <name>_registerRecordDeviceDriver() that is then
> called from the st.cmd file.
> The following patch to base just converts all the non-allowed characters
> in the app name to underscores. Unfortunately, it relies on a change to
> the ioc templates for makeBaseApp.pl, introducing a "_CSAFEAPPNAME_"
> substitution where previously there was just "_APPNAME_".
> Is this a candidate for sneaking into R3.14.8? Can anyone suggest a
> better way?
> Index: src/registry/registerRecordDeviceDriver.pl
> --- src/registry/registerRecordDeviceDriver.pl (revision 67)
> +++ src/registry/registerRecordDeviceDriver.pl (working copy)
> @@ -15,6 +15,11 @@
> $numberDeviceSupport = 0;
> $numberDriverSupport = 0;
> +# PND 2005-08-31 avoid C errors by using only allowed characters in
> identifiers
> +# Requires a corresponding change in the substitution of st.cmd files
> +$c_bad_ident_chars = '[^0-9A-Za-z_]';
> +$subname =~ s/$c_bad_ident_chars/_/g;
> open(INP,"$file") or die "$! opening file";
> while(<INP>) {
> next if m/ ^ \s* \# /x;
> Index: src/makeBaseApp/top/iocBoot/ioc/st.cmd@Common
> --- src/makeBaseApp/top/iocBoot/ioc/st.cmd@Common (revision 67)
> +++ src/makeBaseApp/top/iocBoot/ioc/st.cmd@Common (working copy)
> @@ -9,7 +9,7 @@
> ## Register all support components
> dbLoadDatabase("dbd/_APPNAME_.dbd",0,0)
> -_APPNAME__registerRecordDeviceDriver(pdbbase)
> +_CSAFEAPPNAME__registerRecordDeviceDriver(pdbbase)
> ## Load record instances
> #dbLoadRecords("db/xxx.db","user=_USER_Host")
> Index: src/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS
> --- src/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS (revision 67)
> +++ src/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS (working copy)
> @@ -7,7 +7,7 @@
> dbLoadRecords("../../db/_APPNAME_.db","user=_USER_")
> Index: src/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks
> --- src/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks (revision 67)
> +++ src/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks (working copy)
> @@ -16,7 +16,7 @@
> cd top
> #dbLoadRecords("db/_APPNAME_.db","macro=value")
> Index: src/makeBaseApp/makeBaseApp.pl
> --- src/makeBaseApp/makeBaseApp.pl (revision 67)
> +++ src/makeBaseApp/makeBaseApp.pl (working copy)
> @@ -14,6 +14,8 @@
> %release = (TOP => $app_top);
> @apps = (TOP);
> &GetUser; # Ensure we know who's in charge
> &readRelease("configure/RELEASE", \%release, \@apps) if (-r
> "configure/RELEASE");
> &readRelease("configure/RELEASE.$ENV{EPICS_HOST_ARCH}", \%release,
> \@apps)
> @@ -93,6 +95,7 @@
> $line =~ s/_TEMPLATE_TOP_/$app_template_top/go;
> $line =~ s/_TOP_/$app_top/go;
> $line =~ s/_APPNAME_/$appname/g;
> + $line =~ s/_CSAFEAPPNAME_/$csafeappname/g;
> $line =~ s/_APPTYPE_/$apptype/go;
> $line =~ s/_ARCH_/$arch/go if ($opt_i);
> $line =~ s/_IOC_/$ioc/g if ($ioc);
> @@ -122,6 +125,7 @@
> foreach $ioc ( @ARGV ) {
> ($appname = $ioc) =~ s/App$//;
> + ($csafeappname = $appname) =~ s/$c_bad_ident_chars/_/g;
> $ioc = "ioc" . $ioc unless ($ioc =~ /^ioc/);
> if (-d "iocBoot/$ioc") {
> print "iocBoot/$ioc exists, not modified.\n";
> @@ -137,6 +141,7 @@
> foreach $app ( @ARGV ) {
> ($appname = $app) =~ s/App$//;
> $appdir = $appname . "App";
> if (-d "$appdir") {
> print "$appname exists, not modified.\n";
> Peter Denison, Senior Software Engineer
> Diamond Light Source Ltd., Diamond House, Chilton, Didcot, Oxon, OX11
> 0DE
> Tel: +44 1235 778511
- 3.14 build system doesn't cope with hyphens in IOC names Denison, PN (Peter)
RE: 3.14 build system doesn't cope with hyphens in IOC names Denison, PN (Peter)
<2005>
<2005>
