Subject: |
3.14 build system doesn't cope with hyphens in IOC names |
"Denison, PN \(Peter\)" <[email protected]> |
To: |
Date: |
Thu, 1 Sep 2005 13:48:22 +0100 |
The build system in R3.14 won't cope with IOC names containing hyphens
(or any other character permitted in filenames, but not permitted in C
identifiers). This is a problem for us with our current naming
convention. It occurs because the auto-generated
<name>_registerRecordDeviceDriver.cpp file uses the app name to
construct a function <name>_registerRecordDeviceDriver() that is then
called from the st.cmd file.
The following patch to base just converts all the non-allowed characters
in the app name to underscores. Unfortunately, it relies on a change to
the ioc templates for makeBaseApp.pl, introducing a "_CSAFEAPPNAME_"
substitution where previously there was just "_APPNAME_".
Is this a candidate for sneaking into R3.14.8? Can anyone suggest a
better way?
Index: src/registry/registerRecordDeviceDriver.pl
--- src/registry/registerRecordDeviceDriver.pl (revision 67)
+++ src/registry/registerRecordDeviceDriver.pl (working copy)
@@ -15,6 +15,11 @@
$numberDeviceSupport = 0;
$numberDriverSupport = 0;
+# PND 2005-08-31 avoid C errors by using only allowed characters in
identifiers
+# Requires a corresponding change in the substitution of st.cmd files
+$c_bad_ident_chars = '[^0-9A-Za-z_]';
+$subname =~ s/$c_bad_ident_chars/_/g;
open(INP,"$file") or die "$! opening file";
while(<INP>) {
next if m/ ^ \s* \# /x;
Index: src/makeBaseApp/top/iocBoot/ioc/st.cmd@Common
--- src/makeBaseApp/top/iocBoot/ioc/st.cmd@Common (revision 67)
+++ src/makeBaseApp/top/iocBoot/ioc/st.cmd@Common (working copy)
@@ -9,7 +9,7 @@
dbLoadDatabase("dbd/_APPNAME_.dbd",0,0)
-_APPNAME__registerRecordDeviceDriver(pdbbase)
+_CSAFEAPPNAME__registerRecordDeviceDriver(pdbbase)
## Load record instances
#dbLoadRecords("db/xxx.db","user=_USER_Host")
Index: src/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS
--- src/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS (revision 67)
+++ src/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS (working copy)
@@ -7,7 +7,7 @@
dbLoadRecords("../../db/_APPNAME_.db","user=_USER_")
Index: src/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks
--- src/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks (revision 67)
+++ src/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks (working copy)
@@ -16,7 +16,7 @@
cd top
#dbLoadRecords("db/_APPNAME_.db","macro=value")
Index: src/makeBaseApp/makeBaseApp.pl
--- src/makeBaseApp/makeBaseApp.pl (revision 67)
+++ src/makeBaseApp/makeBaseApp.pl (working copy)
@@ -14,6 +14,8 @@
%release = (TOP => $app_top);
@apps = (TOP);
&GetUser; # Ensure we know who's in charge
&readRelease("configure/RELEASE", \%release, \@apps) if (-r
"configure/RELEASE");
&readRelease("configure/RELEASE.$ENV{EPICS_HOST_ARCH}", \%release,
\@apps)
@@ -93,6 +95,7 @@
$line =~ s/_TEMPLATE_TOP_/$app_template_top/go;
$line =~ s/_TOP_/$app_top/go;
$line =~ s/_APPNAME_/$appname/g;
+ $line =~ s/_CSAFEAPPNAME_/$csafeappname/g;
$line =~ s/_APPTYPE_/$apptype/go;
$line =~ s/_ARCH_/$arch/go if ($opt_i);
$line =~ s/_IOC_/$ioc/g if ($ioc);
@@ -122,6 +125,7 @@
foreach $ioc ( @ARGV ) {
($appname = $ioc) =~ s/App$//;
+ ($csafeappname = $appname) =~ s/$c_bad_ident_chars/_/g;
$ioc = "ioc" . $ioc unless ($ioc =~ /^ioc/);
if (-d "iocBoot/$ioc") {
print "iocBoot/$ioc exists, not modified.\n";
@@ -137,6 +141,7 @@
foreach $app ( @ARGV ) {
($appname = $app) =~ s/App$//;
$appdir = $appname . "App";
if (-d "$appdir") {
print "$appname exists, not modified.\n";
Peter Denison, Senior Software Engineer
Diamond Light Source Ltd., Diamond House, Chilton, Didcot, Oxon, OX11
0DE
Tel: +44 1235 778511
- Re: 3.14 build system doesn't cope with hyphens in IOC names Ernest L. Williams Jr.
Re: Fwd: FW: Font problem when using EDM Noboru Yamamoto
<2005>
job openings for Gemini Observatory Matthieu Bec
<2005>
