1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: CA loss package on 1 Hz rate
To: Motoki Ooi <[email protected]>, [email protected]
Date: Wed, 24 Aug 2005 09:01:34 -0400
Hi, Motoki
If I am not mistaken
1. dbGetLink() uses CA monitor if PV is placed on another IOC.
2. I have misunderstanding concerning PV gateway. If it is CAGateway
then you have additional buffer (=possible trouble). My experience (6
months ago) gave awful result at SNS. Then Jeff Hill came and he found
one problem and fixed that. But I didn't use CAGateway after that.
3. CaArchive uses CA monitor if you setup "Monitor" in PV definition. In
another case (without Monitor) CaArchive uses caget or monitor.
(CaArchive does "investigation" or depends of other parameters of engine
level. Manual is not clear and I don't remember well Kay's explanation
because I don't use CaArchive without Monitor.)
About timeout definition in CaArchive. I don't know concerning your
previous explanation "1s CaArchive vs 1.0001s PV period". From my small
experience it works well. I wrote 1s in PV definition and data by
monitor come ~1Hz rate (data timestamp is defined from trigger; 1 Hz
trigger is little less - little more 1 s). But I don't remember any
suitable information about that from CaArchive manual.
About your variants.
	I am sorry but I haven't sense what is difference in your 4
variants.
	If CalcRecord is the same and 4 variants work in the same time
so "miss" ":-)" problem is not in IOC 1st. IOC 2nd has one (!) CA
Channel for CalcRecord - this CaRepeater's care. (Jeff, am I correct?)
	So IOC 1st with CalcRecord and LAN are Ok. CaRepeater of IOC 2nd
is Ok too. Then I don't know :-(
Have a good day, Andrei.
-----Original Message-----
Sent: Tuesday, August 23, 2005 9:25 PM
To: [email protected]
Cc: Liyu, Andrei
Subject: Re: CA loss package on 1 Hz rate
Hi Andrei
I'm sorry, I was misunderstanding about caget.
It was not caget nor camonitor method.
What I want to say is "dbGetLink" using in 'aiRecord.c' and other
record.
In the following four case, No 1 and No 3 is almost perfect.
But  once AiRecord ( or PV gateway) on IOC 2nd is used,
(No 2 and No 4) there is some data loss in archived or camonitored data.
1. CalcRecord(IOC 1st) => LAN => camonitor(IOC 2nd)
2. CalcRecord(IOC 1st) => LAN => aiRecord(IOC 2nd) => camonitor(IOC 2nd)
3. CalcRecord(IOC 1st) => LAN => Channel Archiver(IOC 2nd)
4. CalcRecord(IOC 1st) => LAN => aiRecord(IOC 2nd) => Channel
Archiver(IOC 2nd)
Access method of camonitor and Channel Archiver is differ from AiRecord
or dbGetLink (dbPutLink)?
Motoki Ooi
Liyu, Andrei wrote:
>Hi,
>	I don't use any (sync or async) caget method. I use monitor
>method. So I don't lost data like your case. Also I use caget for
simple
>(=test) program. For normal program monitor is better.
>	I also don't care about CPU loading in my case. I control that
>and I know when program uses that. It is tied to trigger and I know how
>many mc uses BLM thread after trigger. After that CPU is unloaded and
>CAS can take everything.
>Andrei.
>From: Motoki Ooi [mailto:[email protected]]
>Sent: Monday, August 22, 2005 9:08 PM
>To: Liyu, Andrei; [email protected]
Prev: Upcoming EPICS meeting Dalesio, Leo `Bob`
Next: RE: CA loss package on 1 Hz rate Liyu, Andrei
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: CA loss package on 1 Hz rate Jeff Hill
