1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: CA loss package on 1 Hz rate
To: [email protected]
Date: Mon, 22 Aug 2005 10:43:01 -0400
	SNS BLM system has 2 levels. First level is VME based/vxWorks
(IOC). Second level is PC/Windows (PC) - similar CAGateway. IOC sends
data one time per second to PC. Data is arrays (one array (720 floats)
per detector; up to 32 detectors per IOC). Array has information about
serial number of current package. PC checks serial number and prints on
terminal port if data was lost or come twice. Time to time (very seldom)
I read both problems.
	SNS works on 1 Hz now. IOC CPU loading ~ 3-5% and PC CPU loading
5%. On 60 Hz IOC will have 30% on 60 Hz. PC doesn't depend of
accelerator rate but depends from clients quantity.
	I hoped to use CAArchive to find source of problem. But I met
another problem. Archive lost connection to IOC when IOC/PC connection
was Ok.
	Does anyone see this problem? Any other suggestions to find the
source (IOC, network, PC)?
Thanks, Andrei.
RE: CA loss package on 1 Hz rate Jeff Hill
Re: CA loss package on 1 Hz rate Motoki Ooi
Prev: Re: Gateway and EPICS_CA_MAX_ARRAY_BYTES Kenneth Evans, Jr.
Next: RE: CA loss package on 1 Hz rate Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Driver for Rontec D312 XFlash MAX Signal Processing Unit? J. Lewis Muir
