Subject: |
RE: Compiling Channel Archiver version 2 |
"Robert Henning" <[email protected]> |
To: |
"EPICS Tech Talk" <[email protected]> |
Date: |
Mon, 15 Aug 2005 16:26:38 -0500 |
Hi:
On Aug 15, 2005, at 16:02, Robert Henning wrote:
> .../../../../include/string2cp.h:16:36: macro "LOG_MSG" passed 3
> arguments, but takes just 1 ...
> .../../../../include/string2cp.h:16: `LOG_MSG' undeclared (first use
> this
> function)
> .../../../../include/string2cp.h:16: (Each undeclared identifier is
> reported
> only once for each function it appears in.)
> .../CtrlInfo.cpp:194:64: macro "LOG_MSG" passed 2 arguments, but takes
> just 1
For some reason the compiler uses a LOG_MSG macro in your case, even
though the file Tools/MsgLogger.h of the archiver sources declares it as
a printf-style function:
void LOG_MSG(const char *format, ...);
Are you using modified sources that
patch a #define for LOG_MSG into the sources?
Is your compiler's search path setup such that it somehow finds another
definition for LOG_MSG?
-Kay
Thanks Kay,
I just realized that some of the header files in the extensions include
directory were not up to date so I simply removed the files and ran make
again. Now everything compiles fine.
Rob
Re: Compiling Channel Archiver version 2 Kay-Uwe Kasemir
Re: DM2K on MacOSX(10.3) Noboru Yamamoto
<2005>
subArray processing (when comments and code disagree) Lawrence T. Hoff
<2005>
