1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: VxWorks - Timer Problem
To: Darrell Nineham <[email protected]>
Cc: [email protected]
Date: Fri, 12 Aug 2005 11:49:58 -0500
I'd like to suggest that you use the 'operating-system-independent' EPICS routines rather than the vxWorks routines.  In that way your driver would be useable on other platforms as well.
Have a look at the APS Event System module in http://www.aps.anl.gov/epics/download/modules/index.php for an example of an R3.13, vxWorks-only driver that has been converted to R3.14, operating-system-independent.  This driver is being used at the APS on RTEMS ColdFire embedded IOCs with the complete APS event receiver in a Stratix II FPGA.
I suppose that I should also put in a recommendation that your base your driver on ASYN.   :-)
On Aug 12, 2005, at 10:54 AM, Darrell Nineham wrote:
Hello fellow tech-talkers,
Apologies for not getting back to you earlier, many thanks for all the
smart suggestions concerning 'arrays in scripts'....problem solved.
now have a problem setting up a timer in a driver, I used the functions
timer_create
timer_connect
timer_settime
When the interrupt occurs I get the error message...
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
VxWorks - Timer Problem Darrell Nineham
Prev: VxWorks - Timer Problem Darrell Nineham
Next: DM2K on MacOSX(10.2) Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
