Dear Fellow Tech-Talkers, Darell, Have a look at the autoSaveRestore package from APS. It doesn't work in the way you describe though, but should be able to do what you want. You specify "autoRestore" files in your startup script containing lists of PV names and values. These files are then read during iocInit and the corresponding values set. It can handle arrays. The files are normally created by the autoSave mechanism but, for special cases such as yours, can also be created manually. The package is used quite widely here at SLS. Regards, David -- [email protected] _/_/_/ _/ _/_/_/ Beamline Control Group, SLS Project _/ _/ _/ Paul Scherrer Institute _/_/ _/ _/_/ CH-5232 Villigen-PSI _/ _/ _/ Tel: +41 56 310 3616 _/_/_/ _/_/_/ _/_/_/ Fax: +41 56 310 3294
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
