Hello Emmanuel,
There are two IP addresses in the diagnostic attached {192.168.1.202,
192.168.1.201}. The source ports vary, but appear to be monotonically
increasing as would be the case with ephemeral port assignments. Therefore,
I am not guessing packet damage is the cause.
I would have a close look at what types of programs are being run at
{192.168.1.202, 192.168.1.201}. You can use netstat to determine what ports
are currently in use, and there are typically OS dependent mechanisms to
identify what process is using what port numbers.
I notice in the diagnostic below that the CA protocol element being rejected
is a CA beacon message. I suspect that someone on your LAN has configured a
CA server to send beacons to the CA server port (an invalid configuration).
More details are in the CA reference manual.
Jeff
> -----Original Message-----
> From: Emmanuel Mayssat [mailto:[email protected]]
> Sent: Saturday, August 06, 2005 3:05 PM
> To: [email protected]
> Subject: CA Errors, but everything works fine !!!
> Hello,
> When I start my IOC, everything works fine.
> Nevertheless, I get the following error/warning messages:
> CAS: Request from 192.168.1.202:33453 => cmmd=13 cid=0x32a type=11
> count=5080 postsize=0
> CAS: Request from 192.168.1.202:33453 => available=0xc0a801ca N=0
> paddr=0x87b7970
> CAS: invalid (damaged?) UDP request from 192.168.1.202:33453 ?
> CAS: request from 192.168.1.201:32836 => "invalid (damaged?) request
> code from UDP"
> CAS: Request from 192.168.1.201:32836 => cmmd=13 cid=0x45f type=11
> count=5074 postsize=0
> CAS: Request from 192.168.1.201:32836 => available=0xc0a801c9 N=0
> paddr=0x87dbf64
> CAS: invalid (damaged?) UDP request from 192.168.1.201:32836 ?
> CAS: request from 192.168.1.201:32837 => "invalid (damaged?) request
> code from UDP"
> CAS: Request from 192.168.1.201:32837 => cmmd=13 cid=0x45f type=11
> count=5072 postsize=0
> CAS: Request from 192.168.1.201:32837 => available=0xc0a801c9 N=0
> paddr=0x87dbf64
> CAS: invalid (damaged?) UDP request from 192.168.1.201:32837 ?
> Any idea of what is going on ?
> Emmanuel
- CA Errors, but everything works fine !!! Emmanuel Mayssat
msi command for building synApps 5.1 J. Lewis Muir
<2005>
<2005>
