since quite a long time I have problems with enums though the CA gateway. They did not update their value correctly even though time and status are OK. I found that the problem occurs only when an alh is also connected to the enum through the gateway. Diagnostic: If an alh is connected, all data is handled differently. A different gdd type is used (dbr_stsack_string instead of value). In gateVcData::setEventData(), the gateway copies the incoming value to an already existing dbr_stsack_string container. See debug output: [Aug 03 16:53:03] gateVcData::setEventData DZ-mbbo1 (1) *********************************************************** dd (incoming) at=16[value] pt=5[aitEnum16] ----------dump This=0x8074000--------- dimension=0 app-type=16 Scalar prim-type=aitEnum16(aitEnumEnum16) value=1 ref-count=1 total-bytes=44, data-size=2, element-count=1 LocalDataFormat -------------------------------------- (4) *********************************************************** event_data(after) at=35[dbr_stsack_string] pt=12[aitContainer] ----------dumping container: ----------dump This=0x80de9d0--------- dimension=1 app-type=35 Container prim-type=aitContainer(aitEnumContainer) ref-count=1 total-bytes=188, data-size=136, element-count=3 destructor=0x8075f08 (0) 0x80dea80 first=0 count=3 Managed Flat LocalDataFormat total in container = 3 ----------dump This=0x80de9fc--------- dimension=0 app-type=19 Scalar prim-type=aitUint16(aitEnumUint16) value=1 ref-count=1 total-bytes=44, data-size=2, element-count=1 LocalDataFormat NoReferencing -------------------------------------- ----------dump This=0x80dea28--------- dimension=0 app-type=20 Scalar prim-type=aitUint16(aitEnumUint16) value=2 ref-count=1 total-bytes=44, data-size=2, element-count=1 LocalDataFormat NoReferencing -------------------------------------- ----------dump This=0x80dea54--------- dimension=0 app-type=16 Scalar prim-type=aitString(aitEnumString) this=0x80dea54 string=0x80e9420<OFF>, length=3, buf length=4, type=Allocated ref-count=1 total-bytes=48, data-size=12, element-count=1 LocalDataFormat NoReferencing -------------------------------------- Here, the input value (1 in this case) is NOT converted to the correct string (still OFF instead of ON). The string keeps its value from connection time. Bugs: gddApplicationTypeTable::smartCopy() does not work correctly then copying application type "value" to "dbr_stsack_string" if the value is an enum. In this copy, gdd::set() is called, which in turn (through aitConvertFromNet() and a conversion table) calls aitConvertStringEnum16() but the enum string table is never passed. Thus, it is not possible to use smartCopy() to copy enum to string. Additionally, without the enum string table or when the number is out of bounds, aitConvertStringEnum16() writes the string representation of the number to a local string buffer but never copies that buffer to the destination string. This is clearly a bug in gdd. aitConvertFixedStringEnum16(), however, does it correctly. The enum string table is stored externally gateVcData::pv_data. In my opinion, it should be stored in the gdd if the gdd is an aitEnum16. Now, gateVcData::setEventData() must handle conversions enums to container (or string) separately, passing the enum string table to the conversion function. But it doesn't. This is a bug in the gateway. Is this conversion to a string really necessary? It does not happen if no alarm handler is connected. An other side effect of the conversion is that DOUBLE values are rounded to only 6 significant digits if an alh is watching them. I think, data should be stored in its native type wherever possible. I will report more when I have solved the problem. So far my advice: Don't connect alh to the same gateway as your "normal" clients. Dirk -- Dr. Dirk Zimoch Swiss Light Source Paul Scherrer Institut Computing and Controls phone +41 56 310 5182 fax +41 56 310 4413
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
