1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: medm and epics ports
To: Emmanuel Mayssat <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 27 Jul 2005 22:54:04 -0400
Give this a try:
Before you start medm (or any CA client) set the EPICS_CA_ADDR_LIST like
so:
export EPICS_CA_ADDR_LIST="<linux-ip-number>:5064  <linux-ip-
number>:5066"
So, bascially the EPICS CA address list can contain a list of space
delimited entries in <IP>:portnumber format.
Ernest L. Williams Jr.
SNS Control Systems Group
ORNL
On Wed, 2005-07-27 at 19:29 -0700, Emmanuel Mayssat wrote:
> Hello all,
> I have 2 epics processes (ioc) running on the same linux computer at 2
> different ports.
> Now, I would like to use 1 top medm display to access the process
> variables of both processes.
> Accessing the PV of one of the iocs is easy.
> export EPICS_CA_SERVER_PORT=5064
> export EPICS_CA_REPEATER_PORT=5065
> medm -x <myMedmDisplay1>.adl
> and
> export EPICS_CA_SERVER_PORT=5066
> export EPICS_CA_REPEATER_PORT=5067
> medm -x <myMedmDisplay2>.adl
> Now if I create a <topDisplay>.adl that consists only of a [related
> display] medm widget that is referencing <myMedmdisplay1>.adl and
> <myMedmDisplay2>.adl, then it does not work.
> I can only access half of the process variables. That is the PVs of
> either the ioc running on port 5064 or 5066.
> How can I contact both ports at once?
> E
medm and epics ports Emmanuel Mayssat
Prev: Making an ioc on linux go much faster Emmanuel Mayssat
Next: problem when running epics ioc in win32 system 刘姝
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: medm and epics ports Emmanuel Mayssat
Next: Making an ioc on linux go much faster Emmanuel Mayssat
