1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: iocLogServer change?
To: Carl Cork <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 21 Jul 2005 16:22:03 -0700 (PDT)
Hi Carl,
The issue is that CMLOG comes packaged with an older version of ACE
(ACE 4.0).  That version did not support RTEMS.
So, I took some of the obvious approaches to that problem and they proved
difficult.  It looks like the API has changed across the last couple of
major releases of ACE.
Ron
|  Ron MacKenzie
|  http://www.slac.stanford.edu/~ronm/
|  mailto:[email protected]
|  This message is from me personally, and does not necessarily
|  reflect the opinion of Stanford University, SLAC, or the US DOE
On Thu, 21 Jul 2005, Carl Cork wrote:
> Have you actually tried to build ACE on RTEMS? The ACE site
> claims to support RTEMS and has comprehensive build/install
> information:
>      http://www.cs.wustl.edu/~schmidt/ACE_wrappers/ACE-INSTALL.html
> The RTEMS archives also have reported success building ACE
> on i386 platforms:
>      http://www.rtems.com/ml/rtems-users/2001/april/msg00030.html
>      http://www.rtems.com/ml/rtems-users/2003/june/msg00118.html
> The CMLOG Client and ClientD code don't appear to have too many VxWorks
> dependencies.
> Maybe porting to RTEMS would be easier than changing iocLogServer?
> Allison, Stephanie wrote:
> > Hi All,
> > We're looking at upgrading iocLogServer so that it either writes
> > messages to a file, like it does now, or forwards the messages to the
> > cmlogServer (which would make iocLogServer be a cmlog client).  We
> > think it's easier to do this than to port the CMLOG client and daemon,
> > and particularly ACE, to our RTEMS IOCs.  Part of this effort would
> > also be to add support for messages that contain both ASCII text and
> > other ASCII "tags" like facility, status, severity, and task name.
> > Any comments?  Dumb idea?  Anybody interested in something like this?  Should it be done in such a way that it can go into some future EPICS base version with the new features enabled via some configure file?  Or left unbundled?
> > Thanks,
> > Stephanie Allison
> > SLAC/SSRL, SLAC/LCLS
> Carl Cork                                 E-Mail:  [email protected]
> Lawrence Berkeley National Lab               TEL: +1 510 486 4295
> One Cyclotron Road, MS 6R2100                FAX: +1 510 486 5664
> Berkeley, CA, USA 94720-8226                 WEB:  www.lbl.gov
Re: iocLogServer change? Matthias Clausen
iocLogServer change? Allison, Stephanie
Re: iocLogServer change? Carl Cork
Prev: Re: iocLogServer change? Carl Cork
Next: Re: iocLogServer change? Matthias Clausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
