1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: #ifdef EPICS3_14
To: Steven Hartman <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 20 Jul 2005 10:29:07 -0500
i use something like this:
/* EPICS base version-specific definitions (must be performed first) */
#include <epicsVersion.h>
#define LT_EPICSBASE(v,r,l) ((EPICS_VERSION<=(v)) && (EPICS_REVISION<=(r)) && (EPICS_MODIFICATION<(l)))
/* Evaluate EPICS base */
#if LT_EPICSBASE(3,14,6)
    #error "EPICS base must be 3.14.6 or greater"
#endif
you can make variations as well..
tschuess!
/david
Steven Hartman wrote:
I have a number of EPICS 3.13 VxWorks device/drivers which I would like to
start using with EPICS 3.14, also with VxWorks. From the "Converting an
EPICS R3.13 application to R3.14.4" document, I see that the addition of
two lines is the minimum that is required.
I would like to be able to maintain the same source code for both the 3.13
and 3.14 apps. So, what I would like to be able to do is something like:
#ifdef EPICS3_14
  #include <epicsExport.h>
  epicsExportAddress(dset,devFoo);
#endif
My question is, Is there already an `official' identifier defined to use
for such preprocessor conditionals that I can use for this?
Argonne National Laboratory
APS Operations Division (AOD)
Beamline Controls and Data Acquisition (BCDA)
EPICS Application Development and Beamline Support
David M. Kline
(630) 252-8639
[email protected]
Re: #ifdef EPICS3_14 Till Straumann
#ifdef EPICS3_14 Steven Hartman
Prev: Re: #ifdef EPICS3_14 Andrew Johnson
Next: Re: #ifdef EPICS3_14 Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
