1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ca gateway configuration for subnets
To: "'EPICS Tech-Talk'" <[email protected]>
Date: Thu, 14 Jul 2005 15:22:10 -0700
Thanks everyone. It sounds like the ca gateway will almost work my purpose (1 NIC, dedicated subnet). The only wrinkle is that we'd like the gateway to receive beacons so we need to add the gateway's broadcast or ip address to the IOC's EPICS_CAS_BEACON_ADDR_LIST; unfortunately this option is only available in R3.14.
Chris
Ralph Lange wrote:
Hmmm....
There is an environment variable (affecting the server side of the Gateway) to mask out single IP addresses so that the Gateway will just ignore name resolution requests from those addresses. That is normally used to prevent loops in a multi-Gateway environment by making Gateways ignore requests from other Gateways.
For the client-side configuration it's either complete subnets or single IP numbers, correct.
I'm not sure if this will work on a single NIC machine, though. You might be running into a situation, where the Gateway (on its server side) while being perfectly configured for a -sip in network A still sees name resolution requests coming form network B since it uses the same NIC. For that case I'm not sure what has to be configured in which way.
For Chris' original description - wasn't the Gateway sitting on a third, separate network anyway? So that clients that want to see the Gateway have to add its IP explicitly to their EPICS_CA_ADDR_LIST anyway? In that case I don't see that there should be a problem for clients on the IOC side network (e.g. the IOCs themselves), as they also would have to explicitly add the Gateway IP to EPICS_CA_ADDR_LIST to have their name resolution requests directed to it. Broadcast requests from clients (empty EPICS_CA_ADDR_LIST) will usually stay within the network. (Only advanced switch/router configuration can change this.)
Cheers,
Ralph
Dayle Kotturi wrote:
Hi Chris,
I have some experience with this. A single host with dual-NICs needed to
act as a CA gateway server in two directions. In order to prevent the
ambiguity you suggest, it was necessary to explicitly lists the sources of
PVs (since there is no way to mask out an IP addr) for each CA gateway
process AND to make sure the CA gateway process ran as the correct IP
(that's the -sip arg or the EPICS_CAS_INTF_ADDR_LIST env var). Note that
wildcards wouldn't work in my case, since if I used them, I'd be including
the server and creating ambiguity.
HTH,
Dayle Kotturi [email protected]
LINAC Coherent Light Source
Stanford Linear Accelerator Center
Re: ca gateway configuration for subnets Ralph Lange
ca gateway configuration for subnets Chris Timossi
Re: ca gateway configuration for subnets Paul Sichta
Re: ca gateway configuration for subnets Maren Purves
Re: ca gateway configuration for subnets Dayle Kotturi
Prev: Re: ca gateway configuration for subnets Ralph Lange
Next: Re: ca gateway configuration for subnets Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
