1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Bacnet communication standard for building and automation
To: [email protected]
Date: Tue, 12 Jul 2005 09:19:36 -0700
Olaf Krebs wrote:
Hello,
does somebody knows about activities in the EPICS community to use the BACnet communication standard to connect plants like air condition, chiller, ...:
This reply was sent earlier to Olaf. I thought it was going out to the list....
I have adapted the bacnet4linux 'stack' to export analog and binary objects to EPICS AI & BI records in a 'read-only' mode. The bacnet stack runs as a separate linux application, and EPICS device support reads the object real-time values (acquired using COV 'monitors') via IPC message queues. I am presently working on exporting bacnet objects that generate alarms and events, to EPICS PVs. This is work in progress, and is not running as a commissioned system yet. Because of it's Linux centricity, it will only run on a linux-hosted soft IOC
Rod Nussbaumer
Electronics Developemnt Group, TRIUMF
Vancouver, BC, Canada.
Bacnet communication standard for building and automation Olaf Krebs
Prev: TSconfigure documentation Denison, PN (Peter)
Next: Difference in shared library build between R3.14.6 and R3.14.7 Denison, PN (Peter)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Bacnet communication standard for building and automation Richard Farnsworth
Next: EPICS <--> PS - Survey Martin Pieck
