1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: UDP send, errno=0x37
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 05 Jul 2005 09:29:07 -0500
Over the weekend we received these error messages from an mv5500 running vxworks 5.5 and epics 3.14.6. As far as I can tell this is an ENOBUFS error. Is this the correct interpretation?
CAS: UDP send to "131.225.231.247:35139" failed because "errno = 0x37"
../online_notify.c: CA beacon (send to "131.225.231.255:5065") error was "errno = 0x37"
CAS: UDP send to "131.225.231.65:33655" failed because "errno = 0x37"
What buffer needs to overflow to get this error? I thought the only UDP messages from an IOC were beacons to port 5065. What are the other UDP messages to ports other than 5065? Could this indicate a problem somewhere else on our network?
Thanks, Geoff
RE: UDP send, errno=0x37 Jeff Hill
Prev: Asyn driver for FLUKE 8508A Kiman Ha
Next: EPICS 3.14.7 static client build Chris Slominski
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Asyn driver for FLUKE 8508A Mark Rivers
Next: RE: UDP send, errno=0x37 Jeff Hill
