1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: question about Channel Archiver
To: huangsong <[email protected]>
Cc: [email protected]
Date: Thu, 23 Jun 2005 00:49:42 -1000
The 'data'command print the correct time.
along with the timezone I assume?... (ie. could say 9pm when it's 9pm, but the timezone could still be set incorrectly).
I had the same problem when I was running an older version of the ChannelArchiver built against epics 3.13.4. Had to manually account for that before doing any queries - thought this was a feature. Updated to ChannelArchiver 1.10.2, built it against epics 3.13.10, and the problem disappeared.
You should also make sure that the file base/src/libCom/tsSubr.c has the DST values properly defined for your timezone. Unless you live in Hawaii (EPICS_TS_MIN_WEST=600) where DST is disabled by default you may see weird 1h/2h offsets if this is not done correctly.
Cheers,
Peter Groszkowski Gemini Observatory
Tel: +1 808 9742509 670 N. A'ohoku Place
Fax: +1 808 9359235 Hilo, Hawai'i 96720, USA
question about Channel Archiver huangsong
Re: question about Channel Archiver Ralph Lange
Re: question about Channel Archiver huangsong
Prev: Re: question about Channel Archiver Thomas Birke
Next: alarm handler beeps on Linux Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
