Thanks for reply.Since you are running a slightly old version of the ChannelArchiver I unfortunately cannot reproduce your problem, but: The ChannelArchiver uses (and used to utilize) the functions provided by the EPICS-Base to do the conversion of timestamps * locattime <-> UTC (or whatever EPICS's base-timezone is) * and in the older versions even to convert timestamp <-> string Nevertheless, in your case, it looks like the timestamp you provide on the command-line is always taken as a UTC-timestamp. This is definitely not the expected behaviour! And I don't have the sources of ChannelArchiver 1.10.2 at hand to look/try it. I just found an old HP-UX-binary of ArchiveExport (version 1.9.2) compiled against EPICS-base 3.13.5 and while playing with the environment (setting EPICS_TS_MIN_WEST and/or TZ to different values) unfortunately does not show the behaviour you observe! Indeed it behaves well - it uses EPICS_TS_MIN_WEST to parse the command-line-arguments and to print the timestamps for the output. So the timestamps printed are always in the range of what I specified on the command-line. TZ has no influence at all. EPICS_TS_MIN_WEST=-480 ./hp700-1.9.2/ArchiveExport -start '01/06/04 02:00:00' -end '01/06/04 02:01:00' directory MDIZ3T5G:current ... Time MDIZ3T5G:current [mA] 01/06/2004 01:59:59.144578069 4.882 01/06/2004 02:00:09.147168847 4.860 01/06/2004 02:00:18.947919171 4.840 01/06/2004 02:00:29.101599783 3.639 01/06/2004 02:00:39.189630846 3.475 01/06/2004 02:00:48.956558186 2.622 01/06/2004 02:00:59.000995515 2.352 01/06/2004 02:01:09.201892629 1.838 EPICS_TS_MIN_WEST=-480 ./hp700-1.9.2/ArchiveExport -start '01/06/04 02:00:00' -end '01/06/04 02:01:00' directory MDIZ3T5G:current ... Time MDIZ3T5G:current [mA] 01/06/2004 01:59:59.797524861 -0.152 01/06/2004 02:00:09.696648741 -0.150 01/06/2004 02:00:19.558158965 -0.153 01/06/2004 02:00:29.772687281 -0.152 01/06/2004 02:00:39.739121581 -0.154 01/06/2004 02:00:49.566553625 -0.154 01/06/2004 02:00:59.764922136 -0.154 01/06/2004 02:01:09.797810589 -0.156 So, sorry, no help actually, just a description of how it "should" behave... Regards, Thomas -- ______________________________________________________________________ /homas.Birke @ bessy.de BESSY Tel: +49 30 6392 4934 Albert Einstein Straße 15 Fax: +49 30 6392 4859 12489 Berlin Germany
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
