Darrel, hi.
I wrote my own support of Hytec8402.
I closed that trouble on upper software level. But, in any case, I would like
to understand situation better.
At first, we use Register. We don’t
need to generate signal (waveform) and we need just stable potential.
At second, doram
is flag in Hytec’s (?) driver. It is not bit in
any register. So let use just register/bit names from manual.
1. manual 3.1 has
information about Register usage. Program should write registers and set
CSR-ARM to 1. Then programs should wait when module dropsCSR-
ARM to 0. This variants takes ~600 000 VME cycles. Also 3.1 hasn’t
any connection to Clock Rate.
2. manual 5.4 informs
about Clock Rate. “Each clock pulse will initiate 16 DAC updates from
memory.” It means the rate is responsible for rate of output signal from
DAC. Manual 3.2 (about Memory usage) has the same information.
Andrei.
-----Original
Message-----
[mailto:[email protected]]
Sent: Friday, June 17, 2005 7:30 AM
To: 'Eric Bjorklund'; Sibley III,
Coles; Williams Jr, Ernest L.
Cc: 'EPICS tech-talk'
Subject: Hytec DAC8402 DAC
Register Write Problem
Dear All,
I have repeated the test
with the present driver and our hardware, and the 'waitcount' is always 0.
If you are using an out
of date version of the driver you need to ensure that the configuration is as
follows....
Hy8402ipConfigure
( 1, 1, 1, 0,
0, 0, 12, 0)
# cardnumber = 1
# vmeslot = 1
# Ipslot = 1
(0=A,1=B,2=C,3=D)
# intnum = 0 (Interrupt
Vector 0=find me one)
# doram = 1 (0 - Output
via Registers & ClockRate 12, 1 - Output via RAM & Set to passed
ClockRate )
# clocksource = 0 (0 - internal, 1 - external)
# clockrate = 12 (10KHz)
# inhibit = 0 (no
inhibit)
Please
try this configuration with the clockrate set to 10Khz otherwise the register
will be updated at 1Hz, hence the large waitcount, and let me know if this
fixes.
Darrell
Nineham
Hytec
Electronics Ltd.
Tel:
+44 (0) 118 975 7770
Fax:
+44 (0) 118 975 7566
Web:
www.hytec-electronics.co.uk
This email and any files
transmitted with it are confidential and intended solely for the use of the
individual or entity to whom they are addressed. If you have received this
email in error, please notify the sender immediately. The views expressed in
the message are those of the individual author and may not necessarily
represent the views of Hytec Electronics Ltd.
-----Original
Message-----
Sent: 16 June 2005 23:49
To: EPICS tech-talk
Subject: Re: Hytec DAC8402
Coles,
Where does the DAC8402 reside in I/O space? We had a similar problem with a
serial driver in A32 space a few years ago. As near as we could tell, the
hardware was working fine, but the register data seemed like it was being
cached (even though it looked like the mapping registers in the BSP were
disabling caching for A32 space). Our fix was to insert a
cacheInvalidate (DATA_CACHE, (void *)statadr, 12);
call into the loop. We never really figured out whether this defeated the
hardware cache, or just broke the loop out of the CPU instruction pipeline, but
it worked.
You might try a bus-analyzer to see how many reads you really are issuing to
the DAC.
Hope this helps...
-Eric Bj.
On Jun 16, 2005, at 10:47 AM, Sibley III, Coles wrote:
Hello,
We
are using a Hytec DAC8402 at SNS for our beam loss monitor reference. The
driver uses far too much CPU time when we update 8 dacs every 5 seconds. In
fact it goes to 100% cpu usage. The offending code is below. We can fix the
code but the question is why does it take so long to set 16 register?
The
8402 can be set to uses registers (for a typical dac application) or memory
(for arbitrary waveforms). We need the typical dac configuration, not the
arbitrary waveforms.
We
are using a Motorola MVME5100 cpu.
The
wait count goes to 600000 in our case, as if statadr was not declared as
volatile or the 512K of memory is getting loaded, not just the 16 registers.
Our WAITLIM has to be set to 1000000.
while(((*statadr&CSR_ARM) !=0) && waitcount <
WAITLIM)waitcount++;
if( waitcount < WAITLIM )
/* set dac value and rearm */
card->pMem->Data[signal]=val;
*statadr |=CSR_ARM;
The
manual says:
While
the unit is ARMed the DACs are constantly refreshed with the contents of the
registers which can be changed during this time. There is a delay which is
fixed of approximately 32us after ARM is set, before all the outputs change
together.”
The
problem seems to be that the ARM stays high far longer than seems reasonable,
as the count rate indicates.
The
initialization in st.cmd is:
Hy8402Configure(1,1,0,0,0,0,0,0)
Hy8402Configure(2,1,1,0,0,0,0,0)
Any
suggestions?
Coles
Sibley
SNS
– ORNL
Controls
Hardware Engineer
865-241-8055
[email protected]
Eric Björklund
Los Alamos Neutron Science Center (LANSCE)
phone: 505-667-6031 email: [email protected]
TSPA :: DUSA=ADTO
