Dalesio, Leo `Bob` wrote: Hi Noboru, I would never want to restrict anything that didn't harmSorry. I had come to conclusion too early. I should have read your post one more again, before writing previous mail. > I intended more to find out why we are looking into many differentones and see if there was a smaller set that would cover everything. Worst case, I was looking to find out what else was available and how well it was being supported. Bob Jun-ichi already explained very well why we, EPICS group in KEK, are working on EPICS port to micro-ITRON, so I will not repeat it. I agree that if would be nice if a small set of RT-OS can cover everything, i.e. cost, performance and maintainability, etc. In this way, we can share much information on the EPICS on these OSes and utilize our resource in very efficient way. As Jeff pointed out: Software is always more robust when there is a larger installed base. If you are the only site with a particular OS port then if you experience an issue that no one else sees you will not have the option of working with other sites to reproduce your problem in order to find a fix. I also support Jeff's comment: I'm not encouraging anyone to commit this work, I would be very happy if our experience on EPICS port to micro-ITRON can help.I have no doubt that the EPICS community will benefit if you take on the port. One advantage of multiple ports may be that OS diversity does tend to uncover implementation problems. Assuming that these problems are fixed, the software should be more robust to changes introduced as it evolves in the future. Someone always has to be the first one in the pool. Best Regards, Noboru
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
