When building for cygwin-x86 I ran into two errors, semi-colons that were not expected by the compiler. I built epics in the 3.14.7 directory and compared it to base-3.14.7 which is right out of the distribution file. diff -r 3.14.7/src/libCom/osi/epicsThread.cpp base-3.14.7/src/libCom/osi/epicsTh read.cpp 32c32 < void epicsThreadRunable::show ( unsigned int ) const {} --- > void epicsThreadRunable::show ( unsigned int ) const {}; Only in 3.14.7/src/libCom/test: O.cygwin-x86 diff -r 3.14.7/src/libCom/test/epicsListTest.cpp base-3.14.7/src/libCom/test/epi csListTest.cpp 192c192 < } --- > }; I installed cygwin, epics base v3.14.7, set EPICS_HOST_ARCH to cygwin-x86, and did a gmake cygwin-x86. Any suggestions? Thanks, Geoff
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
