Iztok Krapec wrote: Hi all! These fields are filled in by the sscan record when it connects to a positioner PV. The sscan record reads the PV's engineering units, display precision, and limits from the record that contains the PV, and it writes them its P1EU, P1PR, P1HR, P1LR fields so that a data acquisition client can later put them into the data file. If the information you're seeing is different from what the record has, then yes, you're probably seeing a symptom of some problem. But if you've written to those fields yourself, and the sscan record is overwriting with zeroes from the record, then the software is doing what it was intended to do. If this isn't the right thing for your application, let's talk. The information is only read at PV-connect time. This occurs whenever the PV name is changed, and at the beginning of every scan. (The sscan record breaks and remakes positioner-PV connections at the beginning of every scan.) -- Tim Mooney ([email protected]) (630)963-1860 Beamline Controls & Data Acquisition Group Advanced Photon Source, Argonne National Lab.
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
