Hi Jeff,
The culprit was a misbehaving channel access client. Somehow it
connected tens of thousands of channels which increased the memory usage
by CA. When it was stopped the memory on the IOC was not returned. Are
there tools to monitor the CA memory usage? Is this the expected
behaviour of CA?
Thanks, Geoff
Jeff Hill wrote:
Geoff,
Use memShow to obtain status of the system pool. A common cause
of system pool depletion will be system pool data structure
corruption, or of course some program continuously allocating
memory that it does not free. The former shows up instantaneously
while the latter generally can be predicted as a trend. If the
problem is easily reproducible you may find that selective use of
the task suspend command can be used to isolate the responsible
thread. Typically a binary search is used where you suspend one
half of the threads initially followed by half of the remaining
half etc to tighten the noose with minimized effort.
With your version of vxWorks the network stack pool shouldn't be
increasing past the limits set when vxWorks is built.
There is an integer level argument to casr that can be used to
get more information about what it has allocated.
Jeff
-----Original Message-----
Sent: Tuesday, May 10, 2005 9:48 AM
To: EPICS Tech-Talk
Subject: excessive ioc memory utilization
When I came in this morning our high voltage iocs are using
excessive
amounts of memory, around 95%. They are all mv2301 processors
with 16MB
of memory running epics 3.14.6 built with vxworks 5.5.1. The
netStackSysPoolShow and netStackDataPoolShow outputs are
reasonable.
There are not an excessive number of channels connected. What
can I use
to look and see where the memory is allocated? Any other
suggestions?
Thanks, Geoff
-> netStackSysPoolShow
type number
FREE : 5991
DATA : 0
HEADER : 0
SOCKET : 21
PCB : 35
RTABLE : 91
HTABLE : 0
ATABLE : 0
SONAME : 0
ZOMBIE : 0
SOOPTS : 0
FTABLE : 0
RIGHTS : 0
IFADDR : 4
CONTROL : 0
OOBDATA : 0
IPMOPTS : 0
IPMADDR : 2
IFMADDR : 0
MRTABLE : 0
TOTAL : 6144
number of mbufs: 6144
number of times failed to find space: 0
number of times waited for space: 0
number of times drained protocols for space: 0
__________________
CLUSTER POOL TABLE
_______________________________________________________________
________________
size clusters free usage
64 1024 965 15123
128 1024 996 1647
256 512 446 10893
512 512 512 0
value = 80 = 0x50 = 'P'
type number
FREE : 5991
DATA : 0
HEADER : 0
SOCKET : 21
PCB : 35
RTABLE : 91
HTABLE : 0
ATABLE : 0
SONAME : 0
ZOMBIE : 0
SOOPTS : 0
FTABLE : 0
RIGHTS : 0
IFADDR : 4
CONTROL : 0
OOBDATA : 0
IPMOPTS : 0
IPMADDR : 2
IFMADDR : 0
MRTABLE : 0
TOTAL : 6144
__________________
CLUSTER POOL TABLE
________________
64 1024 965 15125
128 1024 996 1647
256 512 446 10894
512 512 512 0
-> casr
Channel Access Server V4.11
Connected circuits:
TCP 131.225.231.65:46261(d0olj.fnal.gov): User="d0cal", V4.8,
70
Channels, Priority=0
TCP 131.225.230.156:1026(d0olctl38): User="vxworks", V4.11, 6
Channels,
Priority=80
TCP 131.225.231.39:45142(d0ol57.fnal.gov): User="d0fpd", V4.8,
6
TCP 131.225.231.39:45149(d0ol57.fnal.gov): User="d0fpd", V4.8,
4
TCP 131.225.231.252:60499(d0ol49.fnal.gov): User="d0fpd", V4.8,
4
TCP 131.225.231.252:49088(d0ol49.fnal.gov): User="d0fpd", V4.8,
30
TCP 131.225.231.39:49714(d0ol57.fnal.gov): User="d0fpd", V4.8,
6
TCP 131.225.231.247:42004(d0ol45.fnal.gov): User="d0cal", V4.8,
3
TCP 131.225.231.247:43286(d0ol45.fnal.gov): User="d0cal", V4.8,
128
value = 0 = 0x0
- RE: excessive ioc memory utilization Jeff Hill
<2005>
<2005>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
