1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: semTake failure within ca functions
To: "'Al Honey'" <[email protected]>, <[email protected]>
Date: Thu, 28 Apr 2005 18:19:03 -0600
Allan,
What version of 3.13 EPICS is this occurring in? I am having some
trouble pinning this down to a source code line in the latest
R3.13 so I may have to check out your version form CVS.
Jeff
> -----Original Message-----
> From: Al Honey [mailto:[email protected]]
> Sent: Thursday, April 28, 2005 5:44 PM
> To: '[email protected]'
> Subject: semTake failure within ca functions
> Aloha
> We have two systems that are suffering from occasional semTake
> failures
> within iocinf.c.  Said systems are running an ancient version
> of EPICS but
> there appear to be only minor differences between it and
> R3.13.8, in this
> respect.
> I suspect that this is a timing/synchronization issue, whereby
> the ca_static
> structure is deleted in one task (cac_add_task_variable within
> vxWorks_depen.c) whilst another task is using a semaphore
> within that
> structure (cac_clean_iiu_list within iocinf.c), prior to the
> the first task
> obtaining it's task local copy.
> Is anyone cognizant of a 'patch' to rectify this problem?
> Or, if I am way off base, does anyone have the correct
solution?
> seqAux: A call to "assert (semTake(client_lock,
> WAIT_FOREVER)==OK)" failed
> in ../iocinf.c at 1046
> Sat Apr 23 00:22:15 2005 Please send a copy of the output from
> "tt
> (0x352a320)" and a copy of this message to the author or
> "[email protected]"
> Sat Apr 23 00:22:15 2005 This problem occurred in "@(#)Version
> R3.13.0.beta.12 $$ Date: 1998/08/18 02:02:32 $$"
> Sat Apr 23 00:22:17 2005 filename="../taskwd.c" line number=175
> Sat Apr 23 00:22:17 2005 task 352a320 seqAux suspended
> thanks for any help you can provide
> 	Allan
semTake failure within ca functions Al Honey
Prev: semTake failure within ca functions Al Honey
Next: Meeting Proceedings Dalesio, Leo `Bob`
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
