1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: CA; ca_context_destoy and CA channels
To: "'Liyu, Andrei'" <[email protected]>, <[email protected]>
Date: Thu, 14 Apr 2005 10:01:54 -0600
> Program of next layer creates detector1, detector2 and system1
> objects.
> The layer is interested in data concerning to detectors and
> systems. It wouldn't like to know anything concerning CA.
The typical solution for this sort of problem would be to define
a pure virtual interface class for the entity supplying detector
data. This interface need not have any CA specific details in it.
This interface is passed to the constructor for the detector
objects.
The high level code would call a static factory method in the
detector class to obtain a reference to the virtual interface for
the entity supplying detector data. The static factory method in
the detector might instantiates a CA specific implementation of
the interface, and this interface could be passed to the detector
class constructor.
PS: A C++ based version of the CA client library interface is in
the works and it will definitely directly support this type of
abstraction.
Jeff
> -----Original Message-----
> From: Liyu, Andrei [mailto:[email protected]]
> Sent: Thursday, April 14, 2005 7:21 AM
> To: Jeff Hill; [email protected]
> Just example with some libraries.
> Someone needs play with detector1, detector2, system4. He
> writes
> something like
> class CDetector1{
> 	chid * pSCAIDParameter1;
> 	evid * pSCAMonitorParameter1;
> public:
> 	CDetector1();
> 	~CDetector1();
> 	void vFDataProcessing(...);//work with detector
> 	void vFGetData(...);//next layer get data
> class CDetector2{){...}
> class CSystem1{){...}
> objects.
> systems. It
> Have a good day, Andrei.
> From: Jeff Hill [mailto:[email protected]]
> Sent: Wednesday, April 13, 2005 6:29 PM
> To: Liyu, Andrei; [email protected]
> > 	So I open first thread, create CA context, create first
> CA
> > channel. Then I open second thread, attach to current CA
> > context, create second CA channel.  ... Then I decide to
> > close first CA channel and close context (???!!!). What
> > is behavior CA library? I suppose second CA channel will
> > be closed without normal procedure of closing
> > second channel + its monitor?
> The 2nd channel's subscription (monitor) is removed from the
> IOC,
> the channel is removed from the IOC, the circuit to the IOC is
> disconnected, and the channel is attached to a NOOP CA service.
> > 	But I don't like to close second channel and CA context!
> > Then I should check is that channel latest (is the
> > last channel)? I couldn't find suitable function in CA
> > function API.
> There isn't, currently, an interface for this information in
> the
> library.
> > 	I have once way - hold tracks of my CA channels (minimum
> > is global counter). Usually it could be done. But if program
> > is mixture of different libraries and each library comes to
> > CA library then it becomes impossible.
> No such interfaces (for attaching and incrementing an in use
> count and detaching and decrementing an in use count) currently
> exist. I will add your ideas to Mantis entry 161 (initiated on
> behalf of Ben) for further consideration.
> > But if program is mixture of different libraries and
> > each library comes to CA library then it becomes impossible.
> One would need to carefully consider if these independent
> libraries should share a CA context. If so, perhaps you might
> pass a CA context identifier to these libraries when they
> initialize.
> Jeff
> > Sent: Monday, April 11, 2005 8:57 AM
> > To: [email protected]
> > Subject: CA; ca_context_destoy and CA channels
> > Jeff,
> > 	If I am not mistaken there are not couple features in
> > current CA
> > function interface.
> > 	I can suppose that when you came to multithread CA you
> > added
> > get_current_context and attach functions. But there is not
> > similar
> > mechanism for ca_context_destoy.
> CA
> > context, create
> > second CA channel.  ... Then I decide to close first CA
> channel
> > and
> > close context (???!!!). What is behavior CA library? I
> suppose
> > second CA
> > channel will be closed without normal procedure of closing
> > second
> > Then I
> > should check is that channel latest? I couldn't find suitable
> > function
> > in CA function API. Maybe get_current_context has something.
> > But it is
> > very deep.
> > is
> > global counter). Usually it could be done. But if program is
> > mixture of
> > different libraries and each library comes to CA library then
> > it becomes
> > impossible.
> > Thanks,
> > Andrei.
RE: CA; ca_context_destoy and CA channels Liyu, Andrei
Prev: RE: Possible bug in taskwd Jeff Hill
Next: Job opening: APS Beamline Controls group leader Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: CA; ca_context_destoy and CA channels Liyu, Andrei
Next: EPICS Web Server Problems Ralph Lange
