1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: CA; ca_context_destoy and CA channels
To: Jeff Hill <[email protected]>, [email protected]
Date: Thu, 14 Apr 2005 09:21:04 -0400
Just example with some libraries.
Someone needs play with detector1, detector2, system4. He writes
something like
class CDetector1{
	chid * pSCAIDParameter1;
	evid * pSCAMonitorParameter1;
public:
	CDetector1();
	~CDetector1();
	void vFDataProcessing(...);//work with detector
	void vFGetData(...);//next layer get data
class CDetector2{){...}
class CSystem1{){...}
Program of next layer creates detector1, detector2 and system1 objects.
The layer is interested in data concerning to detectors and systems. It
wouldn't like to know anything concerning CA.
Have a good day, Andrei.
-----Original Message-----
Sent: Wednesday, April 13, 2005 6:29 PM
To: Liyu, Andrei; [email protected]
> 	So I open first thread, create CA context, create first
CA
> channel. Then I open second thread, attach to current CA
> context, create second CA channel.  ... Then I decide to
> close first CA channel and close context (???!!!). What
> is behavior CA library? I suppose second CA channel will
> be closed without normal procedure of closing
> second channel + its monitor?
The 2nd channel's subscription (monitor) is removed from the IOC,
the channel is removed from the IOC, the circuit to the IOC is
disconnected, and the channel is attached to a NOOP CA service.
> 	But I don't like to close second channel and CA context!
> Then I should check is that channel latest (is the
> last channel)? I couldn't find suitable function in CA
> function API.
There isn't, currently, an interface for this information in the
library.
> 	I have once way - hold tracks of my CA channels (minimum
> is global counter). Usually it could be done. But if program
> is mixture of different libraries and each library comes to
> CA library then it becomes impossible.
No such interfaces (for attaching and incrementing an in use
count and detaching and decrementing an in use count) currently
exist. I will add your ideas to Mantis entry 161 (initiated on
behalf of Ben) for further consideration.
> But if program is mixture of different libraries and
> each library comes to CA library then it becomes impossible.
One would need to carefully consider if these independent
libraries should share a CA context. If so, perhaps you might
pass a CA context identifier to these libraries when they
initialize.
Jeff
> From: Liyu, Andrei [mailto:[email protected]]
> Sent: Monday, April 11, 2005 8:57 AM
> To: [email protected]
> Subject: CA; ca_context_destoy and CA channels
> Jeff,
> 	If I am not mistaken there are not couple features in
> current CA
> function interface.
> 	I can suppose that when you came to multithread CA you
> added
> get_current_context and attach functions. But there is not
> similar
> mechanism for ca_context_destoy.
CA
> context, create
> second CA channel.  ... Then I decide to close first CA channel
> and
> close context (???!!!). What is behavior CA library? I suppose
> second CA
> channel will be closed without normal procedure of closing
> second
> Then I
> should check is that channel latest? I couldn't find suitable
> function
> in CA function API. Maybe get_current_context has something.
> But it is
> very deep.
> is
> global counter). Usually it could be done. But if program is
> mixture of
> different libraries and each library comes to CA library then
> it becomes
> impossible.
> Thanks,
> Andrei.
RE: CA; ca_context_destoy and CA channels Jeff Hill
Prev: Re: CA; ca_context_destoy and CA channels Benjamin Franksen
Next: Re: Possible bug in taskwd Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: CA; ca_context_destoy and CA channels Jeff Hill
