1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Logarithmic conversion / Breakpoint tabes
To: Gavin Smith <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 04 Apr 2005 11:34:02 +0200
Hello All,
here at Bessy we use a ai record to read the 0..10V vacuum pressure signal and convert it to the logarythmic value of the vacuum pressure. This is usefull to show bargraphs of the vacuum and most people are just interested in vacuum good or bad . A following calc-record converts it to EGUs for numeric display. The logarythmic value is also the archived one because once (long ago, can't remember the details) we had run into the problem that an archive client tried to represent the vacuum of 1.23 * 10^-8 with a float number. This was the true but undesired value of 0.00000 :-)
Bernhard Kuner
Logarithmic conversion / Breakpoint tabes Gavin Smith
Prev: RE: steppermotor vs. motor record compatibility Mark Rivers
Next: Re: Logarithmic conversion / Breakpoint tabes Gavin Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Logarithmic conversion / Breakpoint tabes Rolf Keitel
