1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: CA gateway failure
To: "Tech-Talk" <[email protected]>
Cc: "'Jeff Hill'" <[email protected]>, "'Andrew Johnson'" <[email protected]>
Date: Tue, 22 Mar 2005 17:28:26 -0600
And then there is Mantis #176 for which the solution is known (and easy) and
Mantis #181, which should be easy.  To say nothing of my favorite, #111,
which can't be that hard and which has a very substantial impact.  All of
these should be included in a 3.14.7 patch.
It is difficult for me to patch base and test because I need to make both
Release and Debug builds on four platforms, then manage these builds and the
many extensions for which I am responsible.  I prefer to rebuild my base as
seldom as possible, since it is so time consuming.  I would expect others do
not want to have to keep installing patches, either.
I believe Jeff means #187 instead of #113 for Rolf's bug.  I have tested
Jeff's changes for this bug, and they appear to work.  I have not, of
course, tested them as included in a patch.
I am intending to try to find ways to fix #113 in the Gateway (or else
demonstrate that it cannot be fixed in the Gateway, whichever happens).  I
just need to find time.
For those that can't remember what the numbers mean:
#176 'bad resource id' message in GW log file (owing to blocking socket)
#181 ca_host_name() now returns the host name of the client, not the
host:port of the server
#111 non-preemptive clients disconnect if ca_poll() isnt called regularly
(even though the server and network connection is ok))
#187 spurious corrupted value when writing through the gateway
#113 FATAL: exception not rethrown message when gateway killed with SIGTERM
on Solaris (and related problems on Linux)
	-Ken
Prev: Re: CA gateway failure Ernest L. Williams Jr.
Next: Re: Support for room temperature and humidity sensors J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Support for room temperature and humidity sensors Wayne Dahl
Next: 'type-punned pointer' warning patch Eric Norum
