1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: error building base 3.14.7 w/ cygwin 1.5.13-1
To: "Dale L. Brewe" <[email protected]>, [email protected]
Date: Wed, 09 Mar 2005 18:16:41 -0500
Dale,
I ran into a similar problem when I tried to build EPICS in a directory outside the root cygwin directory. I see from '/cygdrive/d/' that you are attempting the same. When I moved my top level EPICS directory to be below the cygwin root I had no problem. As far as I could tell the prior attempt led to confusion about paths.
John Dobbins
Lab of Elementary Particle Physics
Cornell University
Dale L. Brewe wrote:
I'm getting the error message below if I try to build epics base 3.14.7 (I also tried 3.14.5 earlier w/ the same result) with cygwin under w2k. I would appreciate any hints. The version of cygwin is 1.5.13-1. This is my first stab at building epics w/ cygwin.
make[3]: Entering directory `/cygdrive/d/epics/base-3.14.7/src/dbStatic/O.cygwin-x86'
.../../../bin/cygwin-x86/e_flex.exe -S../../../include/flex.skel.static ../dbLex.l
"../dbLex.l", line 25: illegal character
"../dbLex.l", line 27: unknown error processing section 1
etc.
Here is a segment of dbLex.l starting at line 18:
static int yyreset(void)
        BEGIN INITIAL;
        return(0);
thanks dale brewe
 Dale L. Brewe
 PNC-CAT/Argonne National Laboratory
 ph: 630 252 0582         fax: 630 252 0580
 Mail:
 Bldg 435E sector 20
 9700 S. Cass Ave.
 Argonne, IL 60439
error building base 3.14.7 w/ cygwin 1.5.13-1 Dale L. Brewe
Prev: error building base 3.14.7 w/ cygwin 1.5.13-1 Dale L. Brewe
Next: Vacancies at Diamond Light Source Heron, M (Mark)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: error building base 3.14.7 w/ cygwin 1.5.13-1 Dale L. Brewe
