On Wednesday 09 March 2005 09:04, Ralph Lange wrote:
> If you want to change field values of records before IOCinit, nothing
> keeps you from setting the additional fields in the plain regular
> fashion from a db file that gets instantiated in a later call to
> dbLoadRecords(). It is perfectly legal to have the same record appear in
> more than one instantiation step. (It might not be explicitly mentioned
> in the doc that this is legal, but I learned that many installations use
> this feature.)
There is one pitfall though, that I have been stumbled over: You should take
care that db files with which you are going to override fields in an already
loaded record are not optimized with dbst. Because dbst silently adds
field(DTYP,"Soft Channel") to all records that don't have a DTYP definition.
Ben
- RE: dbpf before iocInit... Allison, Stephanie
- Re: dbpf before iocInit... Ralph Lange
Re: dbpf before iocInit... Emmanuel Mayssat
error building base 3.14.7 w/ cygwin 1.5.13-1 Dale L. Brewe
<2005>
[Fwd: Who is using what EPICS version] John Dobbins
<2005>
