Dear xuepeng and liushu;
I have guessed that you are trying to make your application with TDS3000 and
asyn driver. However, you are trying to install TDS3000. I am sorry to make
the confusing.
Anyway, I just tried to compile TDS3000 with asyn. I have no problem to
install it in my Ultra-Sparc. Now, I am using different version of EPICS
base and asyn, so, I just compiled R3.14.6, asyn-3.2, tds3000_R1_1 to test
it as the following directory.
Base R3.14.6: /tmp/epics/base-3.14.6
Asyn-3.2: /tmp/epics/asyn-3.2
Seq-2.0.8: /tmp/epics/seq-2.0.8
TDS3000R1.1: /tmp/epics/tds3000
(OS: Solaris8, C-compiler: gcc-3.3.2)
I think the following things in tds3000/configure/RELEASE is a little bit
tricky. I just set it as following.
ASYN=/tmp/epics/asyn-3.2
SNCSEQ=/tmp/epics/seq-2.0.8
EPICS_BASE=/tmp/epics/base-3.14.6
And then, compiling could be finished successfully.
I guess, TDS3000-R1.1 is working with asyn-3.2. Are you using asyn-3.2 now?
Or, would you check up the RELEASE file in tds3000/configure as above?
Sorry again to make the confusing.
Thank you.
Best regards,
Kukhee Kim
March 8, 2005
Kukhee Kim
Instrument & Control, KSTAR
Korea Basic Science Institute
52 Yeoeun-dong, Yusung-gu, Daejeon 305-333
Korea
Email: [email protected]
Tel: +82 42 870 1616 Fax: +82 42 870 1609 Cell: +82 17 513 4849
Sent: Tuesday, March 08, 2005 6:31 PM
To: [email protected]
Subject: re: about Tektronix TDS3000 series oscilloscopesdevice device
support
tech-talk,hi
Dear Kim, Kukhee
Thank you for help!
on the "EPICS" homepage
http://www.aps.anl.gov/epics/modules/instrument/tds3000/index.html , I
downloaded
the software(tds3000_R1-1.tar.gz) from the link. the following is the
installation instructions on the page:
Installation
After obtaining a copy of the distribution, it must be installed and built
for use at your site.
* Create an installation directory for the module, usually this will end
with modules/instrument/tds3000
* Unpack the distribution tar file in the installation directory. The
software appears in a subdirectory named after the release number. cd to
this subdirectory.
* Edit the configure/RELEASE file and set the path to your installation of
EPICS base.
* Run gnumake in the top level directory
After installing the tds3000 device support, download and install the Asyn
Driver Support which the tds3000 needs. This can be found here. Install the
latest version.
I followed every step in the instructions. But I met that error when I ran
gnumake. I don't know why.
- re: about Tektronix TDS3000 series oscilloscopesdevice device support liushu
RE: about Tektronix TDS3000 series oscilloscopesdevice device support Kim, Kukhee
<2005>
<2005>
