tech-talk,hi
Dear Kim, Kukhee
Thank you for help!
the
software(tds3000_R1-1.tar.gz) from the link. the following is the
installation instructions on the page:
Installation
After obtaining a copy of the distribution, it
must be installed and built for use at your site.
- Create an installation directory for the
module, usually this will end with
modules/instrument/tds3000
- Unpack the distribution tar file in the
installation directory. The software appears in a subdirectory named
after the release number.
cd to this subdirectory.
- Edit the configure/RELEASE file and
set the path to your installation of EPICS base.
- Run
gnumake in the top level
directory
After installing the tds3000 device support,
download and install the Asyn Driver Support which the tds3000 needs.
This can be found here. Install the latest version.
I followed every step in the instructions. But I met that error when
I ran gnumake. I don't know why.
Description: GIF image
- RE: about Tektronix TDS3000 series oscilloscopesdevice device support Kim, Kukhee
Re: Who is using what EPICS version Dirk Zimoch
<2005>
<2005>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
