Dear xuepeng;
Have you insert some of user flags in your Makefile to describe the location
asyn driver as the following?
USR_INCLUDE += -I$(AYSN_DRIVER_PATH)/include
USR_DBDFLAGS += -I$(ASYN_DRIVER_PATH)/dbd
asyn_DIR += $(ASYN_DRIVER_PATH)/lib/$(T_A)
And you can also add asyn library for your application as the follwing.
<you_application_name>_LIBS += asyn
Good luck!
Best regards,
Kukhee Kim
March 8, 2005
Kukhee Kim
Instrument & Control, KSTAR
Korea Basic Science Institute
52 Yeoeun-dong, Yusung-gu, Daejeon 305-333
Korea
Email: [email protected]
Tel: +82 42 870 1616 Fax: +82 42 870 1609 Cell: +82 17 513 4849
-----Original Message-----
Sent: Tuesday, March 08, 2005 5:00 PM
To: [email protected] <[email protected]> <[email protected]
Subject: about Tektronix TDS3000 series oscilloscopesdevice device support
tech-talk,hi!
Hello, everyone!
I'm installing Tektronix TDS3000 series oscilloscopesdevice device
support based epics base3.14.6. I did it by Mr.Nick DiMonte's helping
document on the "EPICS"
homepage(http://www.aps.anl.gov/epics/modules/instrument/tds3000/index.html)
, But i met the following error, Can anyone help me?
By the way, I've installed "asynDriver" successfully just like Mr.Marty
Kraimer's method.(http://www.aps.anl.gov/epics/modules/soft/asyn/index.html)
Thank you!
Best regards!
xuepeng from IHEP, China
[zz2@zz tds3000]$ gmake
gmake -C configure install
gmake[1]: Entering directory `/home/zz2/xuepengApp/tds3000/configure'
perl /home/zz2/epics3.14.6/base-3.14.6/configure/tools/convertReleasepl -h
linux-x86 checkRelease
perl /home/zz2/epics3.14.6/base-3.14.6/configure/tools/makeMakefile.pl
O.linux-x86 ../..
mkdir O.Common
gmake -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 install
gmake[2]: Entering directory
`/home/zz2/xuepengApp/tds3000/configure/O.linux-x86'
linux-x86 CONFIG_APP_INCLUDE
linux-x86 RULES_INCLUDE
gmake[2]: Leaving directory
gmake[1]: Leaving directory `/home/zz2/xuepengApp/tds3000/configure'
gmake -C TDS3000 install
gmake[1]: Entering directory `/home/zz2/xuepengApp/tds3000/TDS3000'
gmake -C src install
gmake[2]: Entering directory `/home/zz2/xuepengApp/tds3000/TDS3000/src'
O.linux-x86 ../..//..mkdir O.Common
gmake -C O.linux-x86 -f ../Makefile TOP=../..//.. T_A=linux-x86 install
gmake[3]: Entering directory
`/home/zz2/xuepengApp/tds3000/TDS3000/src/O.linux-x86'
gmake[3]: Leaving directory
Installing dbd file ../..//../dbd/devTDS3000.dbd
mkdir ../../../dbd
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500 -DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX
-D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -fPIC -I.
-I.. -I../..//../include/os/Linux -I../..//../include -I/home/zz2/epics3.14.
6/base-3.14.6/include/os/Linux -I/home/zz2/epics3.14.6/base-3.14.6/include
../devTDS3000.c
./devTDS3000.c: In function `getEthernetName':
./devTDS3000.c:1081: structure has no member named `setEos'
./devTDS3000.c:1085: too few arguments to function
./devTDS3000.c:1110: too few arguments to function
gmake[3]: *** [devTDS3000.o] Error 1
gmake[2]: *** [install.linux-x86] Error 2
gmake[2]: Leaving directory `/home/zz2/xuepengApp/tds3000/TDS3000/src'
gmake[1]: *** [src.install] Error 2
gmake[1]: Leaving directory `/home/zz2/xuepengApp/tds3000/TDS3000'
gmake: *** [TDS3000.install] Error 2
- about Tektronix TDS3000 series oscilloscopesdevice device support liushu
device supports for VMIVME-3123-133 and VMIVME-4105-010 Lei Ge
Re: Who is using what EPICS version Dirk Zimoch
<2005>
re: about Tektronix TDS3000 series oscilloscopesdevice device support liushu
<2005>
