1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Initial STAT and SEVR for soft ai and ao records
To: [email protected], Marty Kraimer <[email protected]>
Date: Thu, 03 Mar 2005 14:42:09 +0100
Benjamin Franksen wrote:
On Wednesday 23 February 2005 19:18, you wrote:
On Wednesday 16 February 2005 20:42, Marty Kraimer wrote:
If all that is desired to to make the record not be in alarm
after initialization then just set
  field(SEVR,"NO_ALARM")
  field(STAT,"NO_ALARM")
  field(UDF,"0")
In the record instance definition.
And it did so because fields STAT and SEVR have no promptGroup attributes, thus are not recognized as DCT fields and thus get eliminated by dbDumpRecord from dbStaticLib. This routine has a 3rd argument 'level', which is documented as follows
0 - write only prompt fields that are different from the default values
1 - write only the fields which are prompt fields
2 - write values of all fields
So there is no way to write all fields that that are different from the default values, regardless of whether they are prompt fields or not.
Note that dbst is used to eliminate default values from the db file, which is very useful for capfast generated db files. Thus, one cannot use level=2 to circumvent this problem.
There are two solutions:
(1) Add promptGroup attributes to the field definitions of STAT and SEVR, effectively making them into DCT fields.
(2) Split argument 'level' into two boolean arguments 'non_prompt_fields' and 'non_default_fields'. Or add a 4th level
3 - write values of all fields that are different from the default values
I prefer solution (1), because it's the least intrusive and easy to realize. I think we'll make this change locally.
I agree.
Adding promptGroup attributes would also make Marty's suggestion available for users of vdct or similar tools, who due to the missing promptGroup do not see STAT and SEVR as fields that can be set.
Generally spoken: Maybe every record field should get a promptGroup attribute as long as it is not completely ignored at boot time. Not commonly used fields could appear in a special group ("GUI_MISC"?) to allow tools to hide them in a sub-menu.
Nevertheless - for dbStaticLib's dbDumpRecord() routine: Shouldn't avoiding defaults and avoiding non-prompt fields be options that can be set independently? As these two features of a record field are perefctly orthogonal, it seems awkward that you're not able to set them individually as dump filters.
Ralph
RE: Initial STAT and SEVR for soft ai and ao records Mark Rivers
Re: Initial STAT and SEVR for soft ai and ao records Marty Kraimer
Re: Initial STAT and SEVR for soft ai and ao records Benjamin Franksen
Prev: Re: Initial STAT and SEVR for soft ai and ao records Benjamin Franksen
Next: Archive Record Zadlo, Conrad G., Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: R3.14.7 build error Zoltan Kakucs
