Oops, let me try gateway Beta12.
-ps
----- Original Message -----
To: <[email protected]>
Sent: Wednesday, March 02, 2005 11:02 AM
Subject: Gateway Build for 3.14.7
I can't build the gateway (2.0.0Beta8) under 3.14.7. It
builds fine for me using 3.14.6. OS is Linux RHEL WS-3,
update 4. The errant output is listed below.
Has anyone else built the gateway with 3.14.7 under Linux?
Any explanation for the errors?
... previous 'good' output snipped ...
-ansi -pedantic -Wtraditional -D_POSIX_C_SOURCE=199506L
-O3 -Wall -Wmissing-prototypes -Woverloaded-virtual -Wwrite-strings
-Wconversion -Wstrict-prototypes -Wpointer-arith -Winline
-DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS
-DHANDLE_EXCEPTIONS -D_X86_ -Dlinux -mcpu=pentium -fPIC -D_REENTRANT
-DUNIX -D_BSD_SOURCE -DEXPL_TEMPL -I. -I.. -I../../../include/os/Linux
-I../../../include -I/home/epics/release/epicsR031407/base/include/os/Linux
-I/home/epics/release/epicsR031407/base/include -c
../gateAsyncIO.cc
In file included from ../gateAsyncIO.cc:24:
../gateResources.h:110: `FILE' was not declared in this
scope
../gateResources.h:110: `fp' was not declared in this
scope
../gateResources.h:110: variable or field `setPutlogFp'
declared void
../gateResources.h:110: syntax error before `{' token
../gateResources.h: In member function `void
gateResources::setReadOnly()':
../gateResources.h:72: `ro' undeclared (first use this
function)
../gateResources.h:72: (Each undeclared identifier is
reported only once for
each function it appears in.)
gateResources::setEventMask(long
unsigned int)':
../gateResources.h:77: `event_mask' undeclared (first use
this function)
../gateResources.h:78: `event_mask_string' undeclared
(first use this function)
gateResources::setConnectTimeout(long int)':
../gateResources.h:86: `connect_timeout' undeclared (first
use this function)
... remainder snipped ...
Paul Sichta
Princeton Plasma Physics Laboratory
609-243-3477 FAX 3030
- Gateway Build for 3.14.7 Paul Sichta
Re: Gateway Build for 3.14.7 Paul Sichta
<2005>
<2005>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
