Has anyone else built the gateway with 3.14.7 under Linux? Any explanation for the errors? ... previous 'good' output snipped ... g++ -ansi -pedantic -Wtraditional -D_POSIX_C_SOURCE=199506L -O3 -Wall -Wmissing-prototypes -Woverloaded-virtual -Wwrite-strings -Wconversion -Wstrict-prototypes -Wpointer-arith -Winline -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -D_X86_ -Dlinux -mcpu=pentium -fPIC -D_REENTRANT -DUNIX -D_BSD_SOURCE -DEXPL_TEMPL -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/epics/release/epicsR031407/base/include/os/Linux -I/home/epics/release/epicsR031407/base/include -c ../gateAsyncIO.cc In file included from ../gateAsyncIO.cc:24: ../gateResources.h:110: `FILE' was not declared in this scope ../gateResources.h:110: `fp' was not declared in this scope ../gateResources.h:110: variable or field `setPutlogFp' declared void ../gateResources.h:110: syntax error before `{' token ../gateResources.h: In member function `void gateResources::setReadOnly()': ../gateResources.h:72: `ro' undeclared (first use this function) ../gateResources.h:72: (Each undeclared identifier is reported only once for each function it appears in.) ../gateResources.h: In member function `void gateResources::setEventMask(long unsigned int)': ../gateResources.h:77: `event_mask' undeclared (first use this function) ../gateResources.h:78: `event_mask_string' undeclared (first use this function) ../gateResources.h: In member function `void gateResources::setConnectTimeout(long int)': ../gateResources.h:86: `connect_timeout' undeclared (first use this function) ... remainder snipped ... Thanks, -- Paul Sichta Princeton Plasma Physics Laboratory 609-243-3477 FAX 3030
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
