Geoff -------- Original Message -------- Subject: network storms and epics Date: Thu, 24 Feb 2005 16:25:10 -0600 From: Geoff Savage <[email protected]> To: EPICS Tech-Talk <[email protected]> Hi, Early Wednesday morning we had two incidents where misbehaving terminal servers were sending out broadcasts on our controls network (100 MB ethernet) at rates around 2 Mega bits per second for 5 minutes. I am in the process of upgrading the firmware on the terminal servers to eliminate this problem. The issue is that I don't fully understand all the alarms that were generated. We saw CPU alarms on mv2301 and mv162 processors running epics 3.14.6 built with vxworks 5.5 using the vxStats v1-2 package. We did not see any alarms from mv2301 processors running epics 3.13.4 built with vxworks 5.3.1. So it looks like vxworks 5.5 does not handle network problems as well as vxworks 5.3.1. I seem to remember something about fixed network buffer sizes in the newer version. But why would this cause the CPU work harder? Some (not all) of the processors with CPU alarms also had voltage monitoring records that went into alarm. We saw no other evidence that the voltages were out of range. In some cases the value that triggered the alarm condition was zero yet no power supplies reported a trip condition or needed to be reset. Is it possible for record scanning to get into a state during periods of high cpu usage that would explain the false alarms? Thanks, Geoff
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
