1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Initial STAT and SEVR for soft ai and ao records
To: [email protected]
Cc: [email protected]
Date: Wed, 23 Feb 2005 07:40:53 -0600
Benjamin Franksen wrote:
On Wednesday 16 February 2005 20:42, Marty Kraimer wrote:
If all that is desired to to make the record not be in alarm after
initialization then just set
   field(SEVR,"NO_ALARM")
   field(STAT,"NO_ALARM")
   field(UDF,"0")
In the record instance definition.
Note that you can leave out SEVR and STAT as these are the default values anyway.
However, at least with 3.13.9 this doesn't work. The record (a bo) is still UDF/INVALID after booting.
Ben
In both 3.13 and 3.14 dbCommon.dbd has the definitions:
       field(STAT,DBF_MENU) {
               prompt("Alarm Status")
               special(SPC_NOMOD)
               menu(menuAlarmStat)
               initial("UDF")
       field(SEVR,DBF_MENU) {
               prompt("Alarm Severity")
               special(SPC_NOMOD)
               menu(menuAlarmSevr)
               initial("INVALID")
Thus the defaults are STAT=UDF and SEVR=INVALID.
Re: Initial STAT and SEVR for soft ai and ao records Benjamin Franksen
RE: Initial STAT and SEVR for soft ai and ao records Mark Rivers
Re: Initial STAT and SEVR for soft ai and ao records Marty Kraimer
Prev: Re: Initial STAT and SEVR for soft ai and ao records Benjamin Franksen
Next: Re: Epics research - RDBMS support for Epics Trivan Pal
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Initial STAT and SEVR for soft ai and ao records Benjamin Franksen
