I chose Red Hat Fedora Core 1 Linux. Why? The limitation that I faced with using Linux was SL-GMS. At the time, I began testing (two years ago) EPICS, SL-GMS software and Linux, only Red Hat version 7.3 was supported by SL-GMS. Today ??? ################################################################### FROM MY DEVELOPMENT NOTES: "Tested Sherrill-Lubinski Graphical Modeling System (SL-GMS) software under Redhat Linux 7.3, 8.0, and 9.0 and Fedora Linux Core 1. Fedora Core 1 is the best choice because a remote X-terminal screen sizing problem has been fixed. Only Fedora Linux Core 1 adjusts the remote screen size to that of the remote X-terminal display. Fedora Core 1 and RedHat Linux 7.3 allow the SL-GMS control window to be moved and resized while using the GNOME or KDE desktop environments. Redhat Linux 8.0 and 9.0 only allowed the SL-GMS window to be moved and resized under the KDE desktop environments. The new Fedora Linux, which replaces RedHat Linux will be supported. RedHat Linux will not be supported anymore." ################################################################### Fedora Core 2 was released after, my development/testing work was terminated. So, I have not tested the facility EPICS code under Core 2 and newer releases. Fedora Core 1 represents the last of the 2.4.x kernel. Fedora Core 2 represents the first of the 2.6.x kernel. Usually the last of a series is the best OS while the first of a series has the most problems.
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
