Data Access Class Library Tutorial
Copyright © 2002 The University of Chicago, as Operator of
Argonne National Laboratory.
Copyright © 2002 The Regents of the University of California,
as Operator of Los Alamos National Laboratory.
Copyright © 2002 Berliner Elektronenspeicherringgesellschaft
für Synchrotronstrahlung.
EPICS BASE Versions 3.13.7 and higher are distributed subject to a
Software License Agreement found in the file LICENSE that is included with
this distribution.
Modified on $Date: 2005/02/22 22:19:56 $
Table of Contents
This document is a tutorial introduction to a generic C++ programming
interface for introspecting proprietary data.
Jeff Hill (LANL SNS Division) and Ralph Lange (BESSY) are responsible for
the design of this interface and the contents of this document.
Data Access is a generic interface for introspection of proprietary data
with complex structure. A program may choose to export its proprietary data
using this interface. Once this is accomplished then any programs that know
the interface may examine and or potentially modify the data. The user is not
required to store his data in a particular format, but nevertheless knowledge
of the structure of the data may be determined at compile time, and therefore
efficient access to the data can be made. A support library is supplied for
copying and comparing between properly interfaced property sets.
Why We Need This
Currently EPICS has a fixed set of meta-data, but this needs to expand
because EPICS base developers can't anticipate all possible meta-data, and
all possible meta-data permutations. Expansion of the toolset will hopefully
accelerate if application developers can define new meta-data. Pivotal to a
tool based approach is proper decoupling of tools from each other so that
changes in one tool do not cause another tool to break. Data Access is about
expanding the meta-data set while keeping the tools properly decoupled. If
the meta-data set is expanded in a data source we must not require that all
of the clients of that source be rewritten.
In multi-agent systems synchronization is a reoccurring theme. Currently,
EPICS synchronizes a single parameter with a fixed set of meta data. Data
Access facilitates synchronization of an arbitrary application defined set of
meta-data with a time stamp, an arbitrary (application defined) event, a
client’s read or write request, or a synchronized multi-channel read /
write.
EPICS needs an application extensible event set. For example, a server
might post an “arcDown” event with an application specific data
capsule. A client might subscribe for event “arcDown” and
specify a subset of meta-data to be acquired from the capsule posted with the
event. It is essential in this scenario for the client and server data spaces
to be decoupled. The Data Access support libraries efficiently copy between
dissimilar, decoupled types.
Intelligent instruments are becoming the norm, and they require message
passing. Devices communicate using arbitrary request / response capsules, and
Data Access interfaces arbitrary data capsules.
Properties
The data access interface requires that all data be assigned a property
name. A property name might be weight, units,
maximum, or potentially any meta-data name and purpose that a group
of programs mutually agree upon. A set of data with unique property names may
be stored in a container, and this container is also assigned a property
name.
Properties are organized in hierarchies. For example, the
weight property might have subordinate high display
limit and low display limit properties that belong to it.
Likewise, the height property might need to have the same
properties assigned to it. If the weight property and the
height property both exist in the same container then the
appropriate subordinate properties may need to have independent values
depending on whether they are used with the weight property or the
height property. Therefore, the weight and
height properties both have optional subordinate properties. This
results in a tree structured property hierarchy.
It is anticipated that the facilities in this library will not be
generally useful unless users develop standards early on for the names and
purposes of the properties shared by cooperating programs.
Interfaces
Programs using the data access interface can be roughly categorized into
three different roles working as a property catalog, a data viewer, or a data
manipulator.
- A property catalog's purpose is to index data that is being exported.
It is intimately familiar with the data and its structure, and is
exporting data in a controlled way to programs that are unfamiliar with
the the internal structure of the data. A property catalog provides
facilities for introspecting all of the available properties within a
data container, and to index any particular property that a user might
specify.
- A data viewer's purpose is to view data presented to the data viewer by
a property catalog. The viewer is allowed to examine the data but may not
modify it.
- A data manipulator's purpose is to examine and modify data presented to
the data manipulator by a property catalog.
All of the interfaces described in this document are in C++ name space
da . The example code that follows assumes that a using
namespace da directive has been seen by the C++ compiler.
using namespace da;
Interfaced data may be stored in any of the C++ primitive types, or in
specialized types for strings and time stamps. Additional specialized types
may need to be supported in the future as convenience or efficiency
dictate.
All interfaced data must be assigned a property name.
A property name can be converted to a property identifier as follows.
#include "daPropertyId.h"
static const propertyId propertyIdWeight ( "weight" );
static const propertyId propertyIdHeight ( "height" );
static const propertyId propertyIdValue ( "value" );
static const propertyId propertyIdHighLimit ( "high limit" );
static const propertyId propertyIdLowLimit ( "low limit );
Built-in precompiled property identifiers will be supplied for some of the
commonly used property names. A partial list follows (the standard property set needs to be defined first
before this can be documented).
A property catalog derives from the interface class
propertyCatalog . The property catalog provides
virtual functions to be called from generic programs which don't
have direct access to the data, but know how to introspect data using the
propertyCatalog interface.
#include "dataAccess.h"
class myGirth : public propertyCatalog {
private:
double height;
double weight;
Frequently it is necessary to traverse through all of the published
properties. For example, a utility program could be used to archive many
different types of data to and from disk storage — as long as each
type of data provides an implementation of a generic property traversal
interface. To this end the data interfacing class provides a
traverse function that in turn calls a reveal
function in the dataViewer interface for each of its
participating properties. This reveal function is passed a
propertyId and a C++ const reference to
the property value. There are many overloaded reveal functions
in the dataViewer allowing any of the C++ native storage types
to be used.
void myGirth::traverse ( dataViewer & viewer ) const
viewer.reveal ( propertyIdHeight, this->height );
viewer.reveal ( propertyIdWeight, this->weight );
A similarly structured non-const traverse
function must also be provided for traversing the data in situations when it
might be modified. In this situation we might choose to provide access only
to a subset of data members that are allowed to be modified. There are also
many overloaded reveal functions in the
dataManipulator interface. The overloaded reference to
the property value passed to the reveal functions in the
dataManipulator is modifyable (is not
const ).
traverseModifyStatus myGirth::traverse ( dataManipulator & manipulator )
return tmsSuccess;
When a data interfacing class must verify that a value modified by the
reveal function is within application defined limits for a
particular property it will need to pass a reference to a temporary variable,
initialized to the current value of the property, to the reveal
function. If, after reveal returns, this temporary variable is
out of range, then failure status is returned to indicate that the request
was invalid, and therefore the property was not modified.
double tmpWeight = this->weight;
manipulator.reveal ( propertyIdWeight, tmpWeight );
if ( tmpWeight < 0.0 )
return tmsOutOfRangeLow;
if ( tmpWeight > 10.0 )
return tmsOutOfRangeHigh;
this->weight = tmpWeight;
return tmsSuccess;
When a robustly interfaced property set calls reveal
functions in the dataManipulator interface multiple times for
multiple properties from within its traverse function then
special care might be taken to postpone all property updates until after all
of the calls to the reveal functions complete so that the
container might be left in a consistent state if any one of the modified
parameter is out of range. Here is an example.
void myGirth::traverse ( dataManipulator & manipulator )
double tmpHeight = this->height;
manipulator.reveal ( propertyIdHeight, tmpHeight );
if ( tmpHeight < 0.0 )
if ( tmpHeight > 10.0 )
this->height = tmpHeight;
return tmsSuccess;
Subordinate Container Traversal
Suppose that we have limit properties and would like to publish them using
the data access interfaces. As expected, we will need to create an
interfacing class for the limits with traverse functions for the limit
properties.
class myLimits : public propertyCatalog {
private:
double highLimit;
double lowLimit;
void myLimits::traverse ( dataViewer & viewer ) const
viewer.reveal ( propertyIdHighLimit, this->highLimit );
viewer.reveal ( propertyIdLowLimit, this->lowLimit );
Next, we might add limits to the myGirth class.
private:
double height;
double weight;
myLimits limits;
Next, we need to bind the limits subordinate properties to the height and
weight properties. This is accomplished in the traverse function for the
myGirth class by passing an additional
propertyCatalog referencing parameter for the limits when
calling reveal for the height and weight properties.
viewer.reveal ( propertyIdHeight, this->height, this->limits );
viewer.reveal ( propertyIdWeight, this->weight, this->limits );
A program might choose to extract out of a data container only the
specific properties that it needs, and would therefore need to locate a
particular property in an unknown container indexed only by its property
identifier. For example, we might choose to move data between dissimilar
container types. Compared to the traversal mechanism above, we expect to
introduce an additional degree of flexibility required by certain
applications at the expense of some loss of runtime efficiency. Data that is
interfaced for this type of access must provide the following function.
void myGirth::find ( const propertyId & type, dataViewer & adt ) const;
The find interface allows the programmer complete flexibility
when implementing the indexing mechanism. A prototype indexing
locator class that has proven to have good performance during
testing is shown in the example below, but its use is not required, and for
containers with a limited number of properties a cascaded if statement may
prove to be the simplest and possibly (probably) also the best performing
approach.
Recognition that indexing mechanisms can be greatly simplified when
containers have a limited number of properties may prove to be an impetus to
design property hierarchies with a limited number of properties on each
level.
To use this locator class we must add some class, but not
object, specific data members to the data interfacing class.
#include "daLocator.h"
private:
static bool init;
static locator;
Here is an example.
void myGirth::find ( const propertyId & id, propertyViewer & viewer ) const
myData::locator.callExportFunction ( *this, id, viewer );
Next, "binding" member functions are added for each property with indexed
access.
void myGirth::heightReadBinder ( propertyViewer & viewer ) const
Finally, these "binding" member functions must be installed into the
locator . This operation would be typically performed only once
during initialization.
myGirth::myGirth ()
if ( myGirth::init == false ) {
myGirth::locator.installExportFunction ( propertyIdHeight, heightReadBinder );
myGirth::locator.installExportFunction ( propertyIdWeight, weightReadBinder );
myGirth::init = true;
Note that the central aspect of the find function is that it
provides random access to the properties in a container, and we can conclude
that the implementor of the dataCatalog is not in
control of the order of access or the comprehensiveness of access to a set of
properties. Therefore, a non-const version of the
find interface employing a dataManipulator is
not provided because it is necessary for the implentor of a
dataCatalog to be in complete control of the consistancy and
completeness of modifications made to a property set (see property catalog traversal discussion).
The data access library provides support for assignment and equivalence
operations. Users may perform assignment and equivalence comparison between
two dataCatalog interfaced operands. If the assignment or
equivalence comparison fails then failure status is returned from the
function implementing the operation. For example, during assignment, if a
property in the left hand side operand is missing in the right hand side
operand then asUndefinedProperty is returned. The library does
not implement operator = and operator == for class
propertyCatalog, but all of the necessary infrastructure is provided should a
user chose to do so within another class. For example, functions are provided
to convert failure status into a C++ exception. Functions are also provided
for comparison and equivalence operations where one of the operands is a
dataCatlog and the other is a stringSegment (see
also strings).
enum assignStatus {
asSuccess = 0,
asOutOfRangeLow = 1,
asOutOfRangeHigh = 2,
asInvalidState = 3,
asIncompatibleTypes = 4,
asElementIndexOverflow = 5,
asUndefinedElements = 6,
asUndefinedProperty = 7,
asUnableToExtend = 8,
asUnexpected = 9
epicsShareFunc assignStatus assign (
propertyCatalog & lhs, const propertyCatalog & rhs );
const stringSegment & rhs, const propertyCatalog & rhsMeta );
stringSegment & lhs, const propertyCatalog & lhsMeta,
const propertyCatalog & rhs ) ;
arraySegment & lhs, const propertyCatalog & lhsMeta,
const arraySegment & rhs, const propertyCatalog & rhsMeta );
epicsShareFunc void throwExceptionIfUnsuccessful ( assignStatus );
enum equivStatus {
esEqual = 0,
esNotEqual = 1,
esIncompatible = 2,
esElementIndexOverflow = 3,
esUndefinedElements = 4,
esUndefinedProperty = 5
epicsShareFunc equivStatus equiv (
const propertyCatalog & lhs, const propertyCatalog & rhsMeta );
const arraySegment & lhs, const propertyCatalog & lhsMeta,
bool equivStatusToBool ( equivStatus stat );
As with scalar properties, arrays are interfaced by calling a
reveal function in the dataViewer or
dataManipulator from the dataCatalog 's
traverse or find function. The only difference
being that, instead of passing a scalar value, an arraySegment
interface is passed to the reveal function. Arrays of all C++
primitive types are revealed by using a single reveal function
in the dataViewer or dataManipulator that requires an
arraySegment C++ reference.
#include "daArray.h"
class myArray : public arraySegment {
private:
float chunkOne[1024];
float chunkTwo[1024];
class myArrayData : public propertyCatalog {
private:
myArray array;
void myArrayData::traverse ( propertyViewer & viewer )
viewer.reveal ( propertyIdValue, this->array );
Array Bounds
Information about the bounds of an array is provided using the
arrayBounds interface. The arrayBounds interface is
a subset of the arraySegment interface.
unsigned myArray::numberOfDimensions () const {
return 1u;
arrayBounds::bound myArray :: getBound ( unsigned dimension ) const {
arrayBounds::bound bd;
bd.first = 0;
if ( dimension == 0u ) {
bd.count = sizeof ( chunkOne ) + sizeof ( chunkTwo );
else {
bd.count = 1;
return bd;
Array Traversal
Arrays may be stored in non-contiguous blocks of memory. This allows for
improved memory management (less fragmentation). The
arraySegment interface can be used to traverse all
of the non-contiguous blocks that form an array. An arrayViewer
reference is passed to the array interfacing traverse function.
The array reveal function (overloaded for each of the supported
primitive types) in the arrayViwer interface is called by the
array interfacing traverse function to publish an array segment.
Here is an example where the array is stored in two non-contiguous blocks.
void myArray::traverse ( arrayViewer & adt ) const {
adt.reveal ( this->chunkOne, sizeof ( this->chunkOne ) );
adt.reveal ( this->chunkTwo, sizeof ( this->chunkTwo ) );
When there are multiple calls to reveal from within
traverse each new block revealed is considered to be a logical
extension of the previous block. That is, if in the
arrayViewer::reveal function each successive segment were pushed
incrementally onto a stack growing the direction that C array index pointers
advance then, after the traverse function completes, the entire array could
be directly indexed on this stack using a C array pointer which has been
initialized to the root of the stack.
If the array is multi-dimensional then array elements are revealed in the
natural order for multi-dimensional arrays in the C language. That is,
elements are revealed in row-major order where the right most subscript in
the C language declaration int matrix [10][10] varies more
rapidly.
Array Slice Traversal
A multi-dimensional slice is specified by a user defined class deriving
from interface arrayBounds (see example above). The slice
defines the first element index and element count
for each dimension of a multi-dimensional array. An arrayBounds
reference specifying the bounds of the slice is passed to the array slice
class mySice : public arrayBounds {
public:
unsigned numberOfDimensions () const;
arrayBounds::bound getBound ( unsigned dimension ) const;
A slice sequence index argument is also passed to the array slice
interfacing traverse function. Consider the traversed slice as a
continuous sequence of array elements in row-major order from the beginning
of the slice (the lowest row-major order element) to its end (the highest
row-major order element). The slice sequence index specifies the total number
of contiguous elements to extract from this sequence after a specified
starting element position in this sequence. A slice sequence index is passed
to the slice traverse function using an
arrayBounds::bound structure which contains a first
sequence element index field and a sequence element count field.
If the count field of the slice sequence index is equal to the
multiple of the count field from each dimension in the slice,
and the first field is zero , then we have requested
traversal of the entire slice.
Similar to ordinary array traverse , the array slice
traverse is also passed an arrayViewer interface
with overloaded reveal functions for the purpose of
incrementally publishing snippets of the array slice sequence using blocks of
elements composed from any of the primitive types.
Here is an example implementation of an array slice traverse
function. It is anticipated that library routines will free casual users from
the burden of writing this type of code.
sliceTraverseStatus myArray::traverse (
arrayBounds & slice,
const arrayBounds::bound & sliceSeqIndex,
arrayViewer & viewer ) const {
// verify that the slice is in bounds
static const unsigned arrayLength =
sizeof ( this->chunkOne ) + sizeof ( this->chunkTwo );
unsigned nDim = slice.numberOfDimensions ();
if ( nDim < 1u ) {
return stsSliceOutOfBounds;
daArrayDescriptor::bound bd = slice.getBound ( 0u );
if ( bd.count > arrayLength ) {
if ( bd.first > arrayLength - bd.count ) {
// this is one dimensional array - verify that
// any multi-dimensional bounds are scalar
for ( unsigned dim = 1u; dim < nDim; dim++ ) {
arrayBounds::bound multiBd = slice.getBound ( dim );
if ( multiBd.first != 0u || multiBd.count != 1u ) {
// verify that the slice sequence index is within the specified slice
if ( sliceSeqIndex.count >= bd.count ) {
return stsSliceIndexOutOfBounds;
if ( sliceSeqIndex.first > bd.count - sliceSeqIndex.count ) {
bd.first = bd.first + sliceSeqIndex.first;
bd.count = sliceSeqIndex.count
// reveal array slice
const unsigned last = bd.first + bd.count - 1u;
if ( bd.first < sizeof ( this->chunkOne ) ) {
if ( last > sizeof ( this->chunkOne ) - 1u ) {
viewer.reveal ( &this->chunkOne[bd.first], sizeof ( this->chunkOne );
viewer.reveal ( this->chunkTwo, bd.count - sizeof ( this->chunkOne ) );
else {
viewer.reveal ( &this->chunkOne[bd.first], bd.count );
else {
viewer.reveal ( &this->chunkTwo[ bd.first-sizeof ( this->chunkOne ) ], bd.count );
return stsSuccess;
When Native Array Storage Isn't Matching C's Native Row-Major Order
In this situation the user will need to less efficiently call the
reveal functions one element at a time. A somewhat parallel
situation will also likely occur to more or less of a degree with certain
multidimensional slices.
All strings are interfaced through the stringSegment
interface so that a wide range of native string storage formats are
supported. In particular, storage of strings in fixed sized non-contiguous
blocks is permitted by the interface. There are reveal functions in the
dataViewer and dataManipulator interfaces for type
stringSegment . It is expected that this interface will be
implemented for all of the most commonly used string data types and therefore
casual users will not need to be familiar with it. The interface is described
in the daString.h and daStream.h header files.
At the highest level a string is considered to be a linear sequence of
tokens convertable to C type unsigned . This
approach allows for wide character types (regional character sets). A string
also has a concept of a current stream position that can be directly
manipulated using the streamPosition interface. A string also
has streamRead and streamWrite interfaces allowing
the string to be converted to and from numeric types while allowing for
regional number format variations.
Implementations of the putChar () function set the token at
the current stream position and advance the stream position by one token.
Implementations of the getChar () function return the token at
Implementations of the stringDiff() function compare the two
specified strings and return a constant indicating the relative sort order of
the two strings. The stringDiff() function is passed a
stringSegment reference and it is expected that implementations
will attempt a dynamic cast of this reference to its derived type in the
interest of optimization and or implementation of local sort order
variations.
enum stringDiff { sdBelow, sdEqual, sdAbove };
class stringSegment : public streamPosition, public primTypeConversion {
public:
virtual ~stringSegment () = 0;
virtual bool getChar ( unsigned & ) const throw () = 0; // returns 0 when end of string is reached
virtual bool putChar ( unsigned ) = 0;
virtual stringDiff compare ( const stringSegment & ) const = 0;
The stream position interface allows the total length of the string, its
current position, and its number of tokens available in memory at the current
position to be queried. Likewise, the current position can be set, all tokens
from the current position to the end of the stream can be removed (pruned),
and any tokens in a cache can be flushed. The first token in the string has
position zero, the second token has position one, and all subsequent tokens
are sequentially numbered. Strings are initialized with the first element in
the string being the current token.
class streamPosition {
public:
virtual size_t length () const throw () = 0;
virtual size_t position () const throw () = 0;
virtual bool movePosition ( size_t newPosition ) throw () = 0;
virtual size_t viewable () = 0;
virtual bool prune () throw () = 0;
virtual void flush () throw () = 0;
The length function returns the total number of elements in
the string. The position function returns the position of the
current token. The movePosition function sets the position of
the current token returning false only if the request is not possible. The
viewable function returns the number of immediately
viewable tokens at the current position. The prune function
removes all tokens from the current position to the end of the string.
Finally, the flush function flushes any cached tokens.
The streamWrite interface facilitates writing of a string or
numeric type at the current position in the string and advancing the current
position to just after the end of what was written. When writing a numeric
type the implementation must first check to see if there is a subordinate
property with property id propertyIdEnumeration (this name might change) and, if it exists, use
that interface to convert to and from a numeric type. Next the implementation
will convert the number to a string allowing for regional variations in
string numeric formats, and or using subordinate properties controlling
string numeric formats such as the ioprecision (number of significant
digits).
enum streamWriteStatus {
swsSuccess = 0,
swsUnableToExtend = 1
class streamWrite {
public:
virtual streamWriteStatus write (
const double &, const propertyCatalog & = voidCatalog ) = 0;
const int &, const propertyCatalog & = voidCatalog ) = 0;
const long &, const propertyCatalog & = voidCatalog ) = 0;
const unsigned &, const propertyCatalog & = voidCatalog ) = 0;
const unsigned long &, const propertyCatalog & = voidCatalog ) = 0;
const epicsTime &, const propertyCatalog & = voidCatalog ) = 0;
const class stringSegment &, const propertyCatalog & = voidCatalog ) = 0;
The streamRead interface facilitates reading of a string or
position to just after what was read. When reading a numeric type the
implementation must first check to see if there is a subordinate property
that interface to convert to the numeric type. Next the implementation will
convert the string to a number allowing for regional variations in string
numeric formats, and or using subordinate properties controlling string
numeric formats such as the precision (number of significant digits).
enum streamReadStatus {
srsSuccess = 0,
srsOutOfRangeLow = 1,
srsOutOfRangeHigh = 2,
srsIncompatible = 3,
srsIncomplete = 4
class streamRead {
public:
virtual streamReadStatus read (
double &, const propertyCatalog & = voidCatalog ) const = 0;
int &, const propertyCatalog & = voidCatalog ) const = 0;
long &, const propertyCatalog & = voidCatalog ) const = 0;
unsigned &, const propertyCatalog & = voidCatalog ) const = 0;
unsigned long &, const propertyCatalog & = voidCatalog ) const = 0;
epicsTime &, const propertyCatalog & = voidCatalog ) const = 0;
class stringSegment &, const propertyCatalog & = voidCatalog ) const = 0;
The data access interface allows enumerated (Limited Set of Labeled
States) data to be stored in any of the primitive types as long as all of the
state set values are convertable to C type int . Be
advised however that it is the responsibility of the implementor of the
traverse and or find function(s) to range check any
modifications made by a propertyManipulator . A simple example of
his type of range checking follows.
traverseModifyStatus myData::traverse ( propertyManipulator & manipulator )
unsigned tmp = this->enumValue;
manipulator.reveal ( propertyIdValue, tmp, this->stateSet );
// range check
if ( tmp != 0 && tmp != 1 ) {
return tmsInvalidState;
this->enumValue = tmp;
return tmsSuccess;
There is also an interface allowing applications to view and manipulate
the supported states. This is accomplished by providing a subordinate
property of primitive type enumStateSet and property id
might change). The enumStateSet interface is described in
the daEnum.h header file. Casual users will probably not
implement this interface relying instead on libraries to instantiate
enumerated state sets.
class enumViewer {
public:
virtual void reveal (
const int state, const stringSegment & ) = 0;
class enumStateSet {
public:
virtual unsigned numberOfStates () const = 0;
virtual void traverse ( enumViewer & ea ) const = 0;
virtual bool matchingState ( const stringSegment & label, int & state ) const = 0;
virtual bool matchingState ( const int state, stringSegment & label ) const = 0;
// return false only if unsuccessful
virtual bool removeAllStates () = 0;
virtual bool removeState ( int state ) = 0;
virtual bool setLabel ( int state, const stringSegment & ) = 0;
The overall design goal was to present concise interface to users and to,
whenever possible, shift programming labor from users to the library
implementors where there is maximum benefit and minimized code
duplication.
Data Access isn't being designed for office computing. For a control
system we need to adhere to some basic principals.
- Design for use in limited memory embedded systems
- Design for efficiency, low latency, and high throughput
- Robustness and quality are paramount
The user should not be required to store his data in a particular format.
Nevertheless, knowledge of the structure of the data must be permitted to be
determined at compile time so that access to the data can be efficient.
The interface must not preclude user data stored in multiple
non-contiguous blocks. Memory management based on fixed sized non-contiguous
blocks allows for predictable free lists based memory allocation which
implies low latency, no memory fragmentation, and predictable latency.
The interface must not require C-RTL general purpose memory management -
AKA malloc . When passing data via data access in high throughput
situation efficiency gets noticed. When the Data Access interface to
application data lifetime is the duration of a function call
malloc is a very high overhead call.
There has been a significant preoccupation surrounding the object code
size of data access and so its necessary to clarify this issue.
Data Access is in essence only an interface. When looking at code size we
are comparing the sizes of the accompanying support library components.
Currently the support library provides equivalence and assignment between
properly interfaces data containers. In an IOC it is unlikely that the
equivalence functionality will be needed and so we should consider the size
only of the assignment component which on linux-x86 amounts
currently to about 43 kB when compiled by gcc 3.2.3. There will
also be another 10kB for property id hashing. It is likely that these numbers
could be reduced, but this is really not a significant overhead (even for
legacy embedded systems) and so perhaps that is not a rational way to spend
time.
When comparing the sizes of object code between C++ and C one must use the
UNIX size utility to judge the true size of the object as it
will be used within a properly built executable, and avoid considering
irrelevant space in the object code file. For example space is used in C++
object code files for symbols that need not require space in a production
executable, and therefore a related issue is that in future versions of EPICS
we should endeavor to use a modern vxWorks configurations that
doesn't require a target resident symbol table.
Whoa, this thing is called Data Access!
Don’t O.O. systems use messages and remote procedure calls?
That’s the new technology!
Data Access was invented for the purpose of passing messages - to specify
the parameters of the messages.
Why not use a data description compiler like XDR, CORBA IDL, or EPICS
DBD.
This is certainly worthy of consideration, but proper decoupling of sender
and receiver data spaces appears to be important for a tool based approach.
Conventional data description compiler based systems require interfaces of
the sender and receiver to be utterly identical parameter-for-parameter,
field-for-field, and bit-for-bit. The sender and receiver must have the same
unique data structure identifier. If not, no communication is possible.
However, consider for example the requirements for future implementations of
EPICS. In these systems events posted to the server may have many associated
subsystem unique properties. Clients will rarely need all of them, and there
will be many permutated subsets requested by a range of different clients.
Likewise, clients written in the past should continue to function if new
properties are added to an event.
Furthermore, schemes like XDR require that the data be stored in, or
converted to, a particular format as produced by the XDR compiler. This works
fine for simple scalar datums, but becomes cumbersome for variable length
datums such as strings and arrays. When complex data is stored in a
proprietary format significant overhead can arrise. For excample, in limited
memory systems it is important to allow scattered, non-contiguous storage of
datums. It must not be required that random sized dynamically allocated
blocks of memory exist only for the short duration that a complex dataum is
passed between two different layers in the system. The XDR approach also
tends to be inflexible when it comes to interfacing with multi-dimensional
arrays.
In contrast, Data Access does not enforce a native storage format and
therefore does not suffer from the above limitations, and our perception is
that this is a more flexible, less intrusive, and better performing
approach.
Where are the size locked types?
Past versions of CA were based on size locked types - i.e. "typedef
epicsInt16 dbr_int_t;". However, in my experience users seldom bothered to
use dbr_xxx_t, and therefore my perspective has evolved. Size locked types
should not be in interfaces used by users. Becauase Data Access uses
overloaded reveal functions the interfcace
automatically binds to the user's selected primitive data type
instead of requiring that users recode to yet-another size locked data type
system. When data access is used with a network protocol there will of course
be a private propertyViewer implementation that is aware of the
size locked types that must be used in network protocols. But this is an
internal matter that should not be exposed to users. IMHO, if users
must be aware of protocol and architecture dependent matters then a
proliferation of mistakes are almost guaranteed. Bugs are an inescapble
result of human nature, but it is always preferable to confine them to the
smallest source code real estate. It is better to deal with protocol and
architecture dependent issues once in a library component instead of multiple
times in each client side tool.
This is a C++ template based interface.
In fact, this is a pure virtual base class based interfaced. Templates are
used only in the implementation of the support library. Templates need
not be seen by users.
This is a data object.
In fact, this is a universal interface to non-uniform data. Proprietary
data storage formats need not change. We are not creating an object
that defines a storage format, allocates space, and stores data.This isn't
another GDD or cdevData.
Its best to code everything in C because C can be called from C++, Java,
Python etc...
It is of course possible to call back and forth between any of these
languages and, IMHO, none of them would be successful if that were not the
case. The C++ interfaces described herein do not have templates in them and
so wrappers can be easily be provided so that they can be called from from C,
Java, Python, etc. A C++ plug in for the propertyCatalog
interface can also quite easily provide access to data maintained by C
programs.
Compared to C, the code and interfaces described herein can be more
efficiently maintained and more efficiently executed at runtime when written
in C++. This maintenance efficiency stems from C++'s template capabilities.
In C we must either write and maintain a program to create the conversion
matrix or else write and maintain many functions which could be supplied in
C++ with one template. The runtime efficiency derives from C++'s overloaded
function and template capabilities. In C, the user would see externally an
interface with a void pointer and an additional parameter specifying a data
type code. Internally a C implementation would call the conversion matrix
using a data type code indexed jump table. With C++ this additional step can
be eliminated through use of overloaded functions.
The C++ approach with overloaded functions is also less error prone for
the user. Contrast C++ overloaded functions with the typical C interface to
this type of functionality requiring a type code and a void pointer. The C
interface is without doubt more error prone leaving problems related to
improperly specified type codes to be discovered (and debugged) at run time.
With C++ overloaded functions the compiler enforces the type system at
compile time.
This interface isn't compatible with pure Java.
A pure Java implementation could also be written. Java does not have
templates so when implementing a conversion matrix for the copy and
assignment operators a program that creates a program would probably need to
be written as would also be the case if this functionality were developed in
pure C. IMHO, this is mostly not a technical issue, but instead a resource
limitation and or administrative issue. With a small amount of up front
planning we could probably write and maintain every component of EPICS in
both C++ and Java as our needs and budgets allow.
Virtual Base Class for Time Stamps?
Currently, time stamps are interfaced through class epicsTime. Should time
stamps be interfaced using a pure virtual base class as has been the standard
approach for all other complex data types such as strings and enumerated
state set descriptions.
$Id: dataAccessTutorial.htm,v 1.7 2005/01/06 00:21:01 jhill Exp
