1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Flavors of Linux
To: Emmanuel Mayssat <[email protected]>
Cc: [email protected]
Date: Tue, 22 Feb 2005 16:42:10 -0600
How do you keep Red Hat 8 up-to-date? Red Hat 8 is no longer supported by Red Hat.
www.fedoralegacy.org suspended it's Red Hat 8 support earlier than it had originally claimed
it would.
Older versions of Red Hat had reasonable lifetimes, but the rate at which Fedora Core is
released (2-3 times per year) makes the Red Hat/Fedora Core line much less appealing.
Kevin Peterson
UNICAT
[email protected]
(630) 252-0869
At 02:08 PM 2/22/2005 -0800, Emmanuel Mayssat wrote:
In our case it is 3rd party support that made us go with Red Hat 8.
If you have devices that will be running on the host, then you want to make sure that you have the kernel module that go with them.
If for example you have frame grabbers, then you want corresponding vendor to have QAed the hardware on this linux platform. Ultimately you want them to support it as well.
Red Hat is a sure bet.
I suspect that any of the major distributions can do the job. It would seem to make the most sense for us to go with the flavor of Linux with the largest user base in the EPICS community.
-- Emmanuel Mayssat Lyncean Technologies, Inc. Direct: 650/320-8300 x409 Cell: 650/793-0626
Re: Flavors of Linux Steven Hartman
Re: Flavors of Linux Geoff Savage
Flavors of Linux Gary P Carr
Re: Flavors of Linux Emmanuel Mayssat
Prev: Data Access Class Library Tutorial Jeff Hill
Next: Re: Flavors of Linux Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Flavors of Linux Emmanuel Mayssat
Next: Re: Flavors of Linux Steven Hartman
