1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Strict aliasing
To: [email protected]
Date: Fri, 18 Feb 2005 17:52:57 +0100
Compiling a Software driver - using gcc 3.4.2 and epics 3.14.6 - gives the following error:
../dev1394.c:178: warning: dereferencing type-punned pointer will break strict-aliasing rules
../dev1394.c:179: warning: dereferencing type-punned pointer will break strict-aliasing rules
../dev1394.c:180: warning: dereferencing type-punned pointer will break strict-aliasing rules
../dev1394.c:181: warning: dereferencing type-punned pointer will break strict-aliasing rules
../dev1394.c:182: warning: dereferencing type-punned pointer will break strict-aliasing rules
../dev1394.c:183: warning: dereferencing type-punned pointer will break strict-aliasing rules
Which is related to these lines in my code:
epicsExportAddress(dset,devAi1394);
epicsExportAddress(dset,devAo1394);
epicsExportAddress(dset,devStringin1394);
epicsExportAddress(dset,devWaveform1394);
epicsExportAddress(dset,devMbbi1394);
epicsExportAddress(dset,devMbbo1394);
Expanding the above macros shows no problem:
extern dset *pvar_dset_devAi1394; dset *pvar_dset_devAi1394 = (dset *)&devAi1394;
extern dset *pvar_dset_devAo1394; dset *pvar_dset_devAo1394 = (dset *)&devAo1394;
extern dset *pvar_dset_devStringin1394; dset *pvar_dset_devStringin1394 = (dset *)&devStringin1394;
extern dset *pvar_dset_devWaveform1394; dset *pvar_dset_devWaveform1394 = (dset *)&devWaveform1394;
extern dset *pvar_dset_devMbbi1394; dset *pvar_dset_devMbbi1394 = (dset *)&devMbbi1394;
extern dset *pvar_dset_devMbbo1394; dset *pvar_dset_devMbbo1394 = (dset *)&devMbbo1394;
When I compile using CFLAG= -fno-strict-aliasing, these warnings go away.
Any clues?
Cheers,
Ahed
# Ahed Aladwan                            #
# SLS Controls / Paul Scherrer Institute  #
# WSLA/208, 5232 Villigen PSI Switzerland #
# Tel:+41 56 310 4594                     #
# Fax:+41 56 310 4413                     #
# www.psi.ch                                                             #
# http://people.web.psi.ch/adwan/                   #
ì
Re: Strict aliasing Eric Norum
Prev: RE: load error for vxworks-ppc403 Jeff Hill
Next: New module versions Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Strict aliasing Eric Norum
