1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Initial STAT and SEVR for soft ai and ao records
To: [email protected]
Cc: [email protected]
Date: Wed, 16 Feb 2005 13:42:59 -0600
I am only answering the problem of using PINI to prevent STAT=UDF and SEVR=INVALID.
If all that is desired to to make the record not be in alarm after initialization then just set
   field(SEVR,"NO_ALARM")
   field(STAT,"NO_ALARM")
   field(UDF,"0")
In the record instance definition.
For example
record(ao,"junk") { field(SEVR,"NO_ALARM") field(STAT,"NO_ALARM") field(UDF,"0") }
With regards to
IMHO it should be a top priority for future EPICS releases to redesign record processing in general, and standard record types in particular, such that the effects of processing are more streamlined and predictable.
I agree.
Marty Kraimer
Benjamin Franksen wrote:
On Wednesday 02 February 2005 17:56, Bernhard Kuner wrote:
Saying PINI=Yes is not "saying this record is processed", it
actually processes the record. That can have major side-effects,
if it has PP or CP links to other records.
Yes, this "side-effects" is what I'd expect. The record will be
processed once and all records that are linked to it / monitore its
value will be updated with the value from the DOL field. That is why
I design an EPICS database. Where is the problem?
The problem is that one may want to achieve certain effects (*) of processing (e.g. resetting the record's stat/sevr), while avoiding certain other effects (e.g. writing to HW). This is only possible with disproportionate effort (e.g. switch record to simulation mode, process, switch to normal mode; costing at least one additional seq record). Such effort not only obscures the database design by littering it with "helper" records, it also wastes resources.
It would help to have a record field (RESET?), similar to the PROC field, with the defining property that writing to it causes re-calculating alarm status/severity, using the current field values, without performing any I/O (link-wise or via device support) other than posting the appropriate events.
The nice & clean solution would be to make this a standard record (i.e. dbCommon) field, and to add a corresponding method to record support entry table, so that this field can be handled by the core. Until then, each record type must handle the new field through its "special" method.
On a more general note, it has been observed by many people that record processing is currently overwraught with too many effects, interacting in a too complex manner, which is furthermore slightly different between record types. All this makes reasoning about an EPICS database a daunting task, up to the point where it is nearly impossible to design a non-trivial database without continual (unit-)testing to verify that what one thinks should work is actually working in practice. (Because quite often, and for mostly obscure reasons, it doesn't.) This is especially true for people who are not (yet) intimately familiar with each of the standard record's own peculiarities.
IMHO it should be a top priority for future EPICS releases to redesign record processing in general, and standard record types in particular, such that the effects of processing are more streamlined and predictable. It would help a lot, if common (record support) code could (& would) be factored out into libraries(**); and if the protocol for record processing could be somewhat more formalized and maybe even partially enforced by the core libraries.
Ben
(*) The term "side-effect" is somewhat inappropriate here, since processing happens only for its effects (it doesn't return any value).
(**) ...which I readily admit is difficult to do in C due to its lack of polymorphism. Heresy: Maybe using C++ wouldn't be such a bad idea, after all.
Re: Initial STAT and SEVR for soft ai and ao records Benjamin Franksen
RE: Initial STAT and SEVR for soft ai and ao records Mark Rivers
Re: Initial STAT and SEVR for soft ai and ao records Bernhard Kuner
Prev: Re: SSCAN and EDM Tim Mooney
Next: load error for vxworks-ppc403 Chris Timossi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Initial STAT and SEVR for soft ai and ao records Benjamin Franksen
Next: Re: Initial STAT and SEVR for soft ai and ao records Benjamin Franksen
