1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: SSCAN and EDM
To: Ned Arnold <[email protected]>
Cc: Iztok Krapec <[email protected]>, [email protected]
Date: Wed, 16 Feb 2005 11:38:57 -0600
Ned Arnold wrote:
Iztok Krapec wrote:
Hi all!
I am using the SSCAN record for scanning and EDM's XY graph to show the results. Is there any way to update the graph each time when new value is added to the arrays of scanned values (DnnDA fields)?
I have the EDM 1-10-1v.
LP
Iztok
How often the array is updated is a function of the SSCAN record and when it decides to post the new array ... I think.
I have used the SCAN record with MEDM and have wrestled with the same need. My solution was to do two plots ... "Scan In Progress" and "Scan Results. "Scan In Progress" plots the current values for the detector vs. the current value of the positioners (DnCV vs PnCV) so it updates at each point. "Scan Results" plots the final arrays. With MEDM, you can put these on top of each other and make one visible at a time (which is cool). An advantage of having both visible is that one can see the previous scan results while the new scan is in progress ("Look, this peak moved!").
I don't know the answer to Iztok's question, but I have some relevant information. I also use two plot displays, one for a scan in progress and one for a completed scan. I don't much like this, but it's the best I've come up with so far.
Currently, the sscan record posts arrays (PnRA/DnnDA) only once per scan,
when the scan is finished.  (It holds those arrays for the data-storage
client, while acquiring the next scan's data into private memory arrays.)
The only way to see data from a scan in progress is to plot the scalar
"current-value" fields.  For example, you could plot D01CV (detector 01
current value) against R1CV (positioner-readback 1 current value).
The medm displays I use for plotting scan data while a scan is in progress
also monitor the VAL and DATA fields.  When a monitor is received from the
VAL field, medm understands that a new data point has been posted, and it
appends the most recently received values of monitored data fields to local
arrays.  (The VAL field is posted every data point, after all data fields
have been posted, and it's the *only* field that is guaranteed to be posted
every data point.  If you just stuff data into arrays whenever you get
monitors, you could end up with 100 X values, but only 98 Y values, because
the sscan record currently doesn't post a scalar PV unless its value has
changed.)
Also, medm monitors the DATA field to tell when a new scan has started.
When DATA -> 0, medm clears its plot arrays in preparation for a new scan.
I would like to add the option of posting array data periodically while a
scan is in progress, but this hasn't yet made it to the top of the list.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab
SSCAN and EDM Iztok Krapec
Re: SSCAN and EDM Ned Arnold
Prev: calc and infinity Dirk Zimoch
Next: Re: Initial STAT and SEVR for soft ai and ao records Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: SSCAN and EDM Ned Arnold
Next: calc and infinity Dirk Zimoch
