Hi all! How often the array is updated is a function of the SSCAN record and when it decides to post the new array ... I think. I have used the SCAN record with MEDM and have wrestled with the same need. My solution was to do two plots ... "Scan In Progress" and "Scan Results. "Scan In Progress" plots the current values for the detector vs. the current value of the positioners (DnCV vs PnCV) so it updates at each point. "Scan Results" plots the final arrays. With MEDM, you can put these on top of each other and make one visible at a time (which is cool). An advantage of having both visible is that one can see the previous scan results while the new scan is in progress ("Look, this peak moved!"). Ned
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
