1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Compumotor 6K8 Driver
To: [email protected], [email protected]
Date: Tue, 15 Feb 2005 13:04:29 -1000 (HST)
Aloha
The Keck observatory uses a Compumotor driver for the AX motor controllers
that was originally developed for the observatory by Jeff Hill. That driver
was extensively modified since then (1995?). It would probably require too
may modifications to be useful with the 6k8 controllers.
In addition, on the other telescope (there are twin Keck 10 meter telescopes)
we use drvAscii layered on top of drvSerial to control Compumotor SX
controllers. I think this solution should readily adapt to any of the
Compumotor controllers that utilize a serial interface.
Unfortunately, I have not had time to convert the drvAscii driver to be
compatible with the async driver. The async driver could be another solution,
as modifying that driver for use with Compumotors should not be too arduous.
AH
> Subject: Compumotor 6K8 Driver
> Date: Tue, 15 Feb 2005 14:16:32 -0600
> Has anybody out there written a driver for the motor record to run a
Compumotor 6K8 8-axis motor Controller by Parker?
> Thanks
> Tim Graber
> Timothy J. Graber
> University of Chicago / CARS
> 9700 S Cass Ave.
> Argonne, IL 60439
> Phone (630)252-0462
> Fax     (630)252-0460
Prev: Compumotor 6K8 Driver Tim Graber
Next: SSCAN and EDM Iztok Krapec
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
