Subject: |
Re: compiler bug in gcc version 2.8.1 (Tornado1) for PPC corrupts floationg point constants? |
"J. Frederick Bartlett" <[email protected]> |
To: |
Jeff Hill <[email protected]>, "'EPICS Tech Talk'" <[email protected]> |
Date: |
Wed, 09 Feb 2005 12:02:35 -0600 |
Jeff,
Several years ago I encountered this problem when I was writing an
EPICS driver for a MIL/STD1553B bus controller under the vxWorks OS.
Another process on the IOC, which did use the FP registers and which had
not set the FP save option in the task status, was throwing FP
exceptions. Although the problem was corrected by setting the
save-option bit, we did discover during the investigation that a FP
register's contents was being altered during the execution of the
driver's interrupt service routine (ISR) and that, even though no FP
operations were being performed in the ISR, the compiler optimization
level that we were using caused the FP registers to be used to store
temporary values. As I recall, changing the compiler optimization level
also eliminated this "hidden" use of the FP registers.
Fritz
Jeff Hill wrote:
-----Original Message-----
is that true for all target architectures or just for
the PPC arch that
Dirk is seeing this on?
The WRS warnings concerning this issue are in an
architecture independent section of the documentation,
and I don't see anything specific on this issue in the
PPC specific section of the vxWorks 5.4 documentation.
A potential pitfall might be that the PPC compiler used
the FP registers to pass integer parameters, and that
the user's ISR didn't anticipate that scenario.
Jeff
Jeff Hill wrote:
Dirk,
I don't know if anyone has made this suggestion, but
watch out for a driver that uses floating point in
its
interrupt service routines as, on vxWorks, the FP
register contents are not saved / restored when
entering
/ exiting interrupt context. The driver must do this
manually if it finds a need to use FP in its ISR.
Jeff
- Re: compiler bug in gcc version 2.8.1 (Tornado1) for PPC corrupts floationg point constants? Kay-Uwe Kasemir
- RE: compiler bug in gcc version 2.8.1 (Tornado1) for PPC corrupts floationg point constants? Jeff Hill
Browsing the ioc error log file Ned Arnold
Re: Browsing the ioc error log file Luedeke Andreas
<2005>
<2005>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
